Review: 77263 BMW M3 (E30)
BMW has only appeared once before in Speed Champions, which is rather surprising given the brand's popularity. However, that scarcity makes 77263 BMW M3 (E30) even more compelling, as there is definite pressure to replicate the classic BMW M3 accurately.
The designer has done an excellent job in some regards, employing lots of creative building techniques and avoiding the need for stickers as much as possible, despite the car's complex livery. However, there are certain issues with the bodywork shape, which is not a surprise given the M3's subtle rounded features.
77263 BMW M3 (E30), 358 pieces.
£22.99 / $29.99 / €27.99 | 6.4p, 8.4c, 7.8c per piece.
This model struggles with the BMW M3's shape, but offers a unique building experience
  • Clever building techniques
  • Many details are brick-built
  • Generous quantity of printed parts
  • Issues with the M3's shape
  • Inaccurate wheels
Minifigure
The driver wears a shirt matching the car itself, displaying the same pattern and racing number on the back. According to BMW's press release for this model, a real version of the minifigure's shirt will be available to purchase in August, which is a good idea, though it looks awkward with long sleeves. Dual-moulded arms would have been nice.
Perhaps more interesting is the hair element, which has not appeared in a new set for a couple of years and is new in magenta. The smiling head is relatively common though and a wrench is included, as normal for Speed Champions sets, despite there being no wheel inserts to remove from the car.
Reference
Source - press.bmwgroup.com
It is hard to define why the BMW E3 is quite so distinctive, which is not necessarily ideal for a LEGO iteration. The shape is reasonably accurate on the whole, but some of the car's gentler curves are almost impossible to recreate at this scale, like those above the front wheel arches. Similarly, while the shape of the front and rear windscreen is fairly close to the real car, that is not quite close enough.
The angular edges are particularly apparent from the sides, not helped by the patterns on the bodywork. However, much of the decoration is actually brick-built and there are lots of printed elements included too, with only fourteen stickers, many of which are quite small. The stickers applied on either side are the most notable, as the bonnet and roof are completely printed.
BMW is known for its use of distinctive kidney grilles on the front of each car, including the M3. While printed parts or stickers could have recreated their shape perfectly, using a pair of black forks is more interesting! Even so, it is a shame the silver trim around the grilles is missing and the trans-yellow headlights are slightly oversized.
Otherwise, all the details look superb. The anniversary livery consists entirely of printed pieces across the front of the car, with 1x2 jumper plates neatly arranged above the wheel arches and matching a printed 1x1 slope on the left side. In addition, I like how the bonnet is angled slightly, which goes some way to avoiding the car looking too blocky.
Unusually for Speed Champions, there is some detail found under the bonnet, which is strange because the engine bay is inaccessible without disassembling the car. A sticker represents part of the engine and looks accurate, but nice though the feature is, it seems a bit useless without a functioning bonnet.
The wheels are peculiar because they are new, presumably created for the M3, but they hardly resemble the wheels on the real car. The tyre sidewalls should be much thicker and the spokes are not accurate either. I wonder whether this element has been created for a future car, though that does not explain its use here. At least the BMW logo printed on the hub looks nice.
It surprises me that a brand new livery was selected for this model, rather than a more familiar and potentially nostalgic colour, or maybe a rally design. This pattern is distinctive though, with no other Speed Champions sets like it. The new dual-moulded windscreen part is used to good effect here, with pillars moulded in black and white.
The vast majority of Speed Champions sets are constructed around a versatile chassis piece introduced in 2023 and I assumed this model would be the same. That is not the case though, with a 6x8 trapdoor frame plate forming much of the chassis instead, which makes space for a unique trim design and 2x2 corner tiles as part of the pattern on the bodywork.
There is still enough room for two minifigures inside, seated in 2x2 slots with a tile underneath. Otherwise, the interior is not quite as detailed or refined as usual, as some colourful parts stay visible and look out of place, but I am not particularly worried about that on a fully enclosed car.
One disadvantage of printed parts is that the designs do not always line up as they should, but there are no such issues here. Perhaps changes have been made to improve how consistently printed parts match up, or maybe I was lucky. Either way, the decoration on the roof and across the back of the car looks perfect.
Even the narrow stripes at the front and rear, under the lights, are printed on 2x2 curved corner plates, which I find impressive. The rear lights are also effective, comprising stacked 1x1 plates laid sideways, while the twin exhausts are accurate as well, represented by binoculars.
77263 BMW M3 (E30) has plenty of positive qualities: its construction is interesting, the livery is faithful to that designed for the M3's fortieth anniversary and there are a huge number of printed elements included, with relatively few stickers. Moreover, I like how forks have been used for the distinctive grilles, despite the missing silver trim.
The trouble is, this model fundamentally fails to capture the shape of its subject. I am not at all surprised because of the subtle rounded edges necessary to recreate the M3, which are pretty much impossible to recreate, although I do not understand why the wheels are inaccurate. This set is fun to build, but as a recreation of the BMW M3 E30, the shape is just wrong.
22 comments on this article
I have no attachment to this car whatsoever and quite like how the set looks livery and all, but it does seem a little odd to decide that because you can’t achieve the exact proportional degree of curves at the right scale, then it’s best to create almost no curves at all. I think it ends up looking less like the car than using too-big curves might have.
I wonder if they decided to make it have goofy livery because this car's shape just doesn't translate to Lego very well and it would look even goofier with one consistent color, and they though a wild paint job would hide that fact. Either way, it's confusing to look at, and as someone who has always appreciated those cars, it's a pass for me.
As ugly as sin but still a must have (and much more attractive than any overpriced Technic Supercar!). Looking forwards to picking up this plus 77264 in a week or so.
By in Luxembourg,
This should have been red. Clear lights with those hole bracket panels to make them look smaller. Spend the sticker budget on actual mesh wheels.
Typically I've really enjoyed a lot of the recent SC, but this is a major miss.
Edit: also, the front and rear bumpers stick out too far.
The one positive about this car is the number of prints. Which makes it even more of a shame that they are wasted on this set. And while it's nice that they seem to align well, the white gaps still kinda ruin it.
The problem with a car like the E30 is that it isn't so much iconic because of its basic shape, but it's all about the details. Details that are impossible te recreate in this scale. And when even the nose is completely off (I mean, the E30 was from an era when the nose of a BMW wasn't just headlights and kidneys....), it ends up being barely recognizable. Maybe some iconic livery could still have saved it somewhat, but instead we get this....
One of the worst SC sets of the 8 wide era.
By in South Africa,
I agree that the trans-yellow headlights are oversized, but way more than slightly. Their treatment in this model makes it look more Golf 1 than E30. Similar headlight treatment to 77237 Dodge Hellcat would have worked much better here. This one is a miss for me too.
I too am disappointed that BMW and Lego didn't choose to recreate a classic racing livery on the M3. I grew up watching these things race and love them to bits! Although one half of the public discourse that I have seen online probably stems from the fact that they ran liveries that are heavily associated with cigarette or alcohol brands so wouldn't be entirely suitable subject matter for a kid's toy in 2026.
The OTHER half of the problem in the public discourse (and more relevant here) is that Lego and BMW showed off pictures of prototype cars that Lego had made in plain white and red, and that's what got everyone talking about it. They look beautiful in those colours. I would love to have one in white... and thankfully Lego is a modular building system that allows me to order the parts to make a plain white one if I want to. That'll be a fun project for the future! For all the red M3 fans... cross your fingers and hope that the windscreen comes out in red at some point. Sorry.
To address the chosen livery for the car, BMW has handily provided various press releases and marketing materials that explain what it is doing with this collaboration with Lego. There's a link above in the body of the text for this review if you want to know more. It's about selling BMW as a brand with the goal of shifting more current-day M-cars and t-shirts for aspirational car owners, or in Lego's case getting BMW fans to take a look at Lego sets and maybe buy one... and another... and another... Simple as that.
And the wheel choice... well. As a road-going car they came out with 15 or 16" wheels from the factory. In race trim in the Group A touring car regulations they ran 18" wheels, which look much cooler and have those low-profile tyres. I think they suit the car really well. From BMW's perspective they might be a hint at the potential for customisation that an M3 owner might pursue. From Lego's perspective it's a new mould that matches a new tyre (from the 77254 Ferrari SF90) with the ability to be used across a range of cars in different colours, which a rendition of a 16" wheel and tyre for Speed Champions might not meet. As Lego experts we all understand what conditions have to be met before a new mould is approved, right?
The main appeal of this set, I think, is the slightly early Futuron 40th Anniversary minifig.
I love the BMW M3. I owned the E46 for several years and it still remains the best car I have ever driven.
However, this looks really poor. I think the wheels are the ultimate let down. You just cannot unsee how awful they look.
I do like the Speed Champions range. Well(ish) priced, fun builds that don't take up too much shelf space and usually do a pretty good job of reflecting the source material.
Think I'll be giving this one a miss though - if it wasn't for the badging and livery, I'd not even be sure it was a BMW, let alone an M3.
Still - they can't get it right all the time. First world problems, etc etc
Other than the shaping, the livery, and the interior, it looks great. I’m not a car guy but I kept thinking everyone was saying it was £30 which seemed too high. The rims seemed an odd choice until I googled and saw similar a number of times. At first glance, my caption for this set would have been, “And this is why we ask Dada to do our stickers.”
In my opinion, I would've loved this as a clean version, and maybe have some M stripes on it too
LEGO REALLY should have made a new mudguard for this, I believe that would have made it look a LOT more like an M3, because the ones they used are 100% wrong.
We need to stop whoever is currently advising corporations on colors and designs.
minority report: I like stickers because they can be left off.
I'll still get it though.
Don't know why, but I like these clever, compact little sets.
It looks great for a car but why the unecessary BMW license because it looks nothing like the original besides the colourscheme..
And again, 8 studs wide but no functions at all! Nothing, nada, niente, nichts..
Lame theme by now, i am certainly over it.
I'm not normally one to complain about how accurate Speed Champions cars are as they are Lego versions not replica kits - try Tamiya* if you want that - but this one is just a bit too 'off'.
I do quite like how this has got the reaction that 'we want prints not stickers' but 'not on a set we want to leave the stickers off'!
*I might be dating myself a bit there.
To me, as a supposed representation of an E30 M3 this thing looks like sh*t. Totally.
The livery is ugly as f*** imho. And not choosing either a classic colour like red or black, or the iconic (for once that term would have been appropriate) DTM livery is a crime!
I love the M3 and already have several scale models of various sizes including the Scalextric DTM version, and never will I buy this absolute POS set!
The designer deserves to be sacked for this abomination which looks NOTHING like an E30 M3!
I consider this set an insult to every BMW M3 fan. Seriously, when I heard they would be doing a Speed Champions M3 I was so excited, but when I saw the actual set I was aghast at what they did.
Rarely did I feel so annoyed and let down by an official set design.
The overall proportions, the wheel arches, the entire front, the greenhouse. Awful. And the only half decent view, the rear, is ruined by the livery which leaves it looking a total mess.
I do like the minifig a lot. She’s cute. I like her hair and her fun shirt.
Ok LEGO, you had your fun with the BS anniversary livery, now bring out the OG E30 M3 we all wanted in plain white, red or black. Thanks.
I would say that’s pretty ugly. Unfortunately there’s no pretty about it. At least it doesn’t come with a terrible price tag.
