Review: 75533 Boba Fett
The Buildable Figures subtheme began in 2015 and has included many popular characters over the last few years. However, the galaxy's most infamous bounty hunter has remained elusive and it appears that demand for his arrival has continued to increase with each passing wave.
Finally, 75533 Boba Fett has been released and this should prove to be among the most popular Buildable Figures yet. I have certainly been looking forward to the set and was thoroughly impressed when images emerged towards the end of last year. Not only does Fett's famed helmet look absolutely brilliant but the worn armour is highly detailed and I like the tattered cape worn over his left shoulder.
Boba Fett stands 25cm in height so is one of the larger Buildable Figures released to date. The model still looks appropriately stocky in relation to the movie though and features plenty of articulation. Ball joints are situated at the neck, shoulders, elbows, wrists, hips, knees and ankles, allowing the figure to be displayed however you wish. I would still love a new hand element with some finger articulation but the closed grip suits Boba Fett.
The high quality of Buildable Figure helmets can always be relied upon and Boba Fett's famous mask is absolutely perfect, as anticipated. The sculpting looks fantastic from every angle, featuring an inset visor and a textured dent which is highlighted in silver. Similar battle wear continues across the front of the helmet and a series of yellow lines are printed on the left temple, just as in the movie.
Silver highlights are absent from the back of the helmet but this area still looks good, including a dark red grille and some moulded dark bluish grey details with a matte finish on the right hand side. Moreover, a small hole allows you to attach the rangefinder. This consists of just three pieces but matches the source material quite well and being able to fold the rangefinder up and down is a welcome feature for display.
The front of the torso is printed with seven sand green armour plates. Only five pieces of armour cover Fett's chest in the movie but the lower plate has been divided into three to fit the contours of this torso component. Nevertheless, the design is very detailed and includes scattered dark bluish grey and metallic silver battle damage, like that seen on the helmet, as well as braided Wookiee hair and a Mandalorian emblem on the right breast. The reddish brown pouches printed on the waist look marvellous too.
Another Mandalorian sigil, representing the skull of a Mythosaur in Legends material, is printed on the left shoulder. This dark red design looks superb against the flame yellowish orange shoulder armour and again includes some battle wear. The Bounty Hunter wears dark red gauntlets which are new in this colour and a black missile is fitted to his left wrist, as shown below. 75107 Jango Fett wore an identical weapon in pearl gold.
The dark red gauntlets confirm that this figure is based upon Boba Fett as he appears in Star Wars Episode VI: Return of the Jedi and his Z-6 jetpack is blue and flame yellowish orange to match. This features rotating thrust nozzles on either side and a flick-fire missile which can be launched by pushing the dark bluish grey plunger underneath. The entire jetpack assembly looks splendid and I am glad that the firing missile is included, although its range is limited.
A soft fabric cape is attached around the neck and the left shoulder. This hangs most naturally over the jetpack but can also be folded behind it for greater accuracy. I think olive green is a suitable choice for its colour, although the cape appears brighter in certain shots from the film. The tattered edges are also very nice and you could crumple the cape by placing it behind the jetpack for an even more worn appearance.
Bounty Hunters must be equipped for every eventuality and Boba Fett therefore carries a selection of knives and other weapons in pockets on his shins. These are printed alongside flame yellowish orange knee pads and I am impressed that the designs vary between the left and right legs so match the movie exactly. Two more pouches, represented by dark tan 2x3 curved slopes, are fitted to the sides of the thigh shells which are new in light bluish grey.
Boba Fett is armed with an EE-3 carbine rifle. The weapons that come with Buildable Figures frequently lack detail as most are constructed around the same spring-loaded missile launcher with a trigger attached beneath the barrel. However, I think this accessory looks marvellous, featuring a narrow scope and a large stock which matches the configuration of the blaster used in Star Wars Episode VI: Return of the Jedi.
I was initially concerned that the stock would hinder poseability. However, the grip has been cleverly offset to ensure that you can create a variety of dynamic poses. The stock looks less impressive from the other side as the dark bluish grey panel is hollow, although I still think this element works well on the whole. Fett's Sacros K-11 pistol would also have been an excellent addition to the set but is not a necessity as the EE-3 carbine rifle is far more prominent and the Sacros K-11 is absent from Return of the Jedi.
Boba Fett is undoubtedly one of the most popular Star Wars characters, despite his limited role in the saga, so a great deal of expectation has been placed upon this figure. Fortunately, 75533 Boba Fett does not disappoint, featuring magnificent detail and extensive articulation which makes it easy to display the model. The helmet is particularly impressive and I like the printed designs on his torso and legs as well.View image at flickr
Furthermore, the EE-3 carbine rifle is excellent and the worn cape looks great in relation to the source material. In fact, the only factor which detracts from the set for me is the price as £25.99 or $29.99 feels quite expensive in relation to other Buildable Figures. Additional details like the cape, the jetpack and the rifle must be taken into consideration but I still think a slightly lower cost would have been more appropriate. Nevertheless, this is a wonderful set and I would definitely recommend it to Boba Fett fans, particularly at a discount.
Thanks to Aaron from Boba Fett Fan Club and Matt from Fantha Tracks for their assistance with this review.
26 comments on this article
By in Colombia,
I think that for the top of the rangefinder the best part is a Gold Ingot in medium stone grey or in black
I haven't gotten into the buildable figures, but I am increasingly impressed by the complex printing these parts get. Each time I see it though I think, why do massive large sets still have stickers? I recently got the Destiny's Bounty as was blown away by the design and look of the ship, and yet even in a large and high-priced set, it still had a rather large sticker sheet.
By in Philippines,
1. That's one half of Death Battle: Boba Fett vs Samus Aran done.
2. Now I really wanna see Sabine Wren in this line.
Totally buying! Great addition to the series. Now to build a large scale Sarlacc to eat him!
Well, as was the case with almost every other ultrabuild I own, I will definitely get this...
...As soon as it hits the bargain bin. Also, it would've been nice to have some more sand green shells, but some is better than none.
Do I love it? Yes.
Will I buy it? Not at $30 freaking dollars, good lord Lego, bugger off with that.
No fireable missile in the backpack?
I'm sure I can easily mod it, but come on Lego, major missed opportunity there.
Interesting his helmet is a new mold and not a recolored Jango helmet. I like the addition of the moveable viewfinder though so it seems to be an upgrade.
Does anyone else think that the Rocket Pack looks horrid. A few Technic liftarms is not an accurate way to represent Bobas Pack, it’s almost as if he designer grabbed whatever parts he or she could do make the rocket firing feature. That alone makes me not want to purchase this.
So agree a Sabine Wren would be great.
I agree the jet pack could be better. It is significantly more blue than I remember, but looks much improved over Jango.
SW buildable figures are the only LEGO series that consistently gets discounted here. Right now, our Lego monobrand is giving them away with a purchase of $30 worth of SW sets. Not sure if anybody actually buys them at full price.
Out of the new Constractible figures this year, I most anticipated Boba Fett.
They did a fantastic job and he makes a great addition to Jango and the overall collection!
Definitely wanting this one (especially as I never got around to picking up Jango) but I agree that the jetpack could use some improvement. The colors are just way too bright.
So far I’ve only really liked the OT characters, Darth Vader (the first one I think is still better) , Storm Trooper and the really excellent Scout Trooper & Speeder Bike. Boba Fett looks great and can’t wait to add him to my collection.
There's a whole host of Rebels characters who would make great figs-too bad it's not likely to happen with the series ending soon and system sets seemingly having ended.
Looking forward to the solo buildable,s but this one is quite good..
OH AND IF ANYONE IS INTERESTED GIZMODO HAS THE AVENGERS 3 SETS ON THERE JUST SEEN 6 OF THEM... WOW
Am I the only one asking for a Gonk Droid buildable figure? No? Ok just me...
"Boba Fett, where?"
Nice photo of Boba fighting alongside his Clone-daddy, Cap'n! Yeah, I've been waiting long time for this figure (a long time...), and I'm happy to finally see Boba Fett in all his glory! That gorgeous helmet sculpt, the wrist-rocket (eh... I'll save the obvious joke for when the B2 Super Battle Droid comes out), and those lovely sand-green shells and panels! I have a couple gripes with the figure, like how I wish they included the flamethrower tube running to his right arm, or how the jetpack missile should reach above the helmet, or how I wish that more of the pieces were more weathered looking, but most of those don't matter. What I think does matter is the unfortunate price point of $30. That premium price was was Darth Vader was worth back in 2015, and the inflation we've seen for this line alone in only 3 years is a little worrisome. Oh well, I'm still getting this guy, he looks pretty snazzy and I can't wait to add him to the collection! Just on a discount...
I'm not crazy about the buildable figures, but Fett's clearly one of the best they've built.
Makes me hope next time they re-design the standard minifigure Boba Fett they can give him his proper jetpack and maybe add in the gauntlets...
By in Costa Rica,
I have been lucky enough to find him. After building Boba I am totally surprised by its complexity and details, had Jango as well, and the way of how LEGO improved from one to the other is fantastic.
Not a fan of these sets because they largely don’t fit, like having a regular clothed person. But with him, and a few others, due to Armor it works.
@mrkey Boba does have a fireable jetpack missile just like Jango, the "firing pin" is just obstructed by his cape in these pictures.
