Review: 75888 Porsche 911 RSR and 911 Turbo 3.0
Now in its fourth year the Speed Champions theme seems to be going from strength to strength, and some are suggesting that the 2018 sets may be the best yet.
Of the 2018 Speed Champions sets, 75888 Porsche 911 RSR and 911 Turbo 3.0 was probably the one that I was most looking forward to getting my hands on. On the basis of the box art, the tricky shape of the classic Porsche 911 Turbo looked to have been impressively reproduced, and I was eager to discover if the build looks as good in person as it does on the screen. Read on to find out….
Box & Contents
The front of the box (above) features the contents of the set posed against a stylised backdrop of Porsche’s Leipzig test track and customer center, while the back of the box (below) showcases various aspects of the set including a couple of simple play features. There are also small images of the real 911 RSR and 911 Turbo on the back of the box so you can see what the builds are supposed to look like.
The box is designed to be opened via a couple of thumb tabs, although as usual I ignored those and instead used a sharp knife to free the flap on the left side so as to minimize box damage. The box contains three sequentially numbered bags of elements, two instruction booklets and a single sticker sheet. The covers of the twin instruction booklets feature imagery that is pretty much identical to the front of the box. In true Speed Champions style the sticker sheet (below) contains well over forty stickers.
The Minifigures
The set contains three minifigures which are, from left to right, a member of the pit crew, a female driver and a male driver. The pit crew member and male driver have the same torso which is exclusive to this set. The torso is printed front and back with a racing suit pattern that includes a grey, red and black striped print which mimics the livery of the 911 RSR. The print also incorporates sponsor logos including Mobil 1 and Porsche Design. Both of these minifigures have generic, unprinted white legs and cheery, single-sided headprints which have previously appeared elsewhere.
The backprinted torso of the female driver features a black jacket pattern with zipper and lime shoulders and pockets. This torso has previously appeared in six sets. Her dark blue legs are unprinted, and her helmet and trans-clear visor are similarly unremarkable. Her cheerful single-sided headprint, which features spectacles with silver frames, has previously appeared as a part of numerous other minifigures.
The Build
First to be assembled is the lime Porsche 911 Turbo. This is constructed in a similar fashion to other Speed Champions vehicles, employing brackets and other SNOT elements to produce a predominantly studless result. The build incorporates a number of new recolours and uncommon elements, including lime 4 x 2 1/2 x 2 1/3 mudguards which are new in this colour. Four stickers are shoehorned onto the front bumper which is attached to the car via uncommon black modified 1 x 2 rounded plates. The area on either side of the bumper is sculpted via the use of a pair of lime 1 x 1 round quarter tiles which are appearing in a set for the first time in this colour, while the bonnet features an uncommon lime 4 x 2 curved slope running down the middle. The technique used to reproduce the distinctive Porsche 911 headlights is ingenious and the result looks excellent! A Technic pin attaches each headlight – a trans-clear round tile – to a Technic 3L axle and pin connector and this then slides into a slot in the body just in front of the front mudguard on each side of the car. The Technic axle and pin connector is new in lime.
The rear licence plate consists of a sticker which is stuck on to to an uncommon lime 1 x 4 plate with two studs. The single exhaust consists of a black 1L bar with 1 x 1 round plate, and the rear bumper is made up of stacked lime and red 2 x 6 plates with rounded corners which have previously appeared in fewer than ten sets in these colours. A lime double cheese slope stickered with Porsche’s ‘turbo’ motif is mounted on the rear of the vehicle. The rear window consists of two stickers that need to be carefully lined up next to each other; in the old days there would have been one large sticker stuck across two elements, a.k.a. STAMPS. This practice has thankfully fallen out of favour, although it would have made stickering the rear window much easier in this particular case. The 911’s huge ‘duck tail’ spoiler utilises a pair of lime 1 x 2 - 1 x 2 inverted brackets which are currently exclusive to the set in this colour, and the roof is made up of a lime 2 x 4 tile which has only previously appeared in a single set in this colour.
Unlike the 911 Turbo the 911 RSR is built on a black 10L vehicle base. Once again the RSR features a number of newly recoloured and uncommon elements. The mudguards are of the same type as those used for the 911 Turbo and have only previously appeared in 5 sets in white, while an uncommon white 3 x 4 x 2/3 wedge with cutout forms part of the bonnet, and the body is contoured via the use of left and right curved 2 x 1 slopes which are new in white. The headlights consist of stickers which attach to white 45 degree 1 x 2 slopes with cutout that have only previously appeared in four sets in this colour. One of the trickiest stickering jobs involves attaching a curved sticker to the top of the trans-black 5 x 4 x 1 1/3 windscreen; if you end up needing to re-align the sticker you might discover that it leaves a nasty, sticky residue so apply with care! The black rims have only previously appeared in two sets, both of them part of the Speed Champions theme.
Similar to the 911 Turbo the RSR has a back window made up of a pair of stickers. These attach to adjacent curved slopes and again need to be carefully applied to avoid making a mess. The rear indicator lights consist of uncommon trans-orange modified 1 x 1 plates with tooth. Not one but two spoilers are mounted on the back of the RSR; the smaller of the two consists of a new black spoiler element, while the larger spoiler is brick-built and attaches to the car via a pair of uncommon black skeleton arms.
In addition to the cars the set includes a small section of pit wall and a lap counter, as well as a pit board for the pit crew. The lap counter is mounted on a white 2 x 4 x 5 inclined stanchion. Interestingly the lap counter is functional, although the downside is that you need to apply stickers to all four faces of a black 2 x 2 brick to make it ‘work’. The stickered brick is placed on a jumper plate, allowing it to be rotated to display the relevant lap number – simple but effective.
The Verdict
I’m a big fan of this set. I think both Porsches look great, and I’d go as far as to say that they're two of my favourite Speed Champions cars so far, with the 911 Turbo my pick of the two.
On the downside, applying the stickers is predictably tedious, principally due to the sheer number involved; applying the stickers is always optional, of course, but I suspect that most purchasers will probably decide to apply them in order to get the most authentic result. Also, the car interiors can only accommodate a single minifigure, and the models are too tall and narrow to be truly faithful to their real life counterparts. Even so, l think that capturing the essence of these distinctive and curvaceous icons in LEGO so well at this scale is still pretty impressive.
The Speed Champions theme is really getting into its stride now, and in my opinion the quality of car design is improving year on year. Assuming that the theme continues in future years I’m genuinely excited to see what vehicles LEGO releases next. Lamborghini, please!
75888 Porsche 911 RSR and 911 Turbo 3.0 is available from LEGO brand stores and S@H at a RRP of £34.99 / US$29.99 / 39.99€. Many thanks to the LEGO Group for providing Brickset with a review copy of the set. All opinions expressed in this review are my own.
22 comments on this article
The Porsches are the only cars that have ever looked any good done at this scale and in this building style - see 75912 in the original line-up. All the major supercars end up far too high or narrow.
Not sure I agree, @Joefish - I've never been much of a fan of the Porsche 911 GTs in set 75912 and think that the 911 Turbo and RSR in this latest set are miles better. I do however agree that pretty much all of the Speed Champions offerings end up too tall and narrow at this scale.
UK Price seems a tad on the expensive side when a single Speed Champions set costs £13. A bit of pit wall & 1 extra figure does not really justify the extra £9.
Should the USA price not be $29.99? Listed as such on both the database and on the US Lego Shop website.
I think the color is just right! (well, a little darker would be better, but not available). I had noticed the genius build for the headlights before. This is a definite buy for me (next month; no Lego for me this month :)
The speed champion sets aren't perfect, but considering the level of detail available in Lego, it's pretty amazing what they've done in these sets.
I had to get this set for the lime green 911 Turbo, which looks great, and is one of those few SC cars that doesn't rely on stickers and has a more "street" than "race track" look. The 911 RSR is nice too, but I would have preferred to buy only the Turbo for 15.00 by itself. On a related note I wish they would have sold the Ferrari 250 GTO in 75889 by itself as a 15.00 set instead of including it in a 100.00 set! Is that evil marketing genious, or in the end does it hurt sales? Which leads us to the previous discussion of declining sales and profits...
Great review! This is a pretty good set for only 29.99, but as I prefer Marvel and Star Wars I probly won't pick it up. Cool set, though.
@LegoSolo77: regarding the 250 GTO. I tend to agree, but luckily to me it doesn't look too convincing anyway, so I may happily pass the set and car, despite the GTO being one of my all-time favorite cars
Stop reviewing Speed Champions sets!!
Probably, the sets of 2018 are the best and after Reading each review, I have a compulsive necessity of buying it!!! What can I do? For now: Ford Fiesta Racing and Ferrari Corsa for sure...but the rest are also good!!
I am becoming crazy!!!
@Joefish I feel like the ford gt (non-racecar) was a super car that turned out great. It seems like lego struggles representing any 2013+ car in lego (at that scale)
it seems like lego was going for a deep-dish stretched tire look with the green one. maybe we will see some more stance-based speed champions in the future.
This is the best Speed Champion set yet. I'm not sure how the Racers/Speed Champions started, but they could get a great deal of detail if the cars were eight wide. At six wide, there is a lot of detail we are missing when you look at them from the front and back. At the same time, making this "small" adds the "playability" factor. Although I'm not sure kids are buying these since the cars they are making are "dream" cars for adults. I like this set... a lot. The 911 looks phenomenal.
By in Philippines,
I love the 911 and I’m so glad it has such a minimal amount of stickers (for the theme).
I'm a huge Porsche fan, and I have been meaning to spend money on LEGO that's not Star Wars for some time. This set will definitely end up in my collection!
I love the way they designed the headlights on the 911 Turbo. Brilliant! The bumpers and tail are also very near to a true 911. And I have to say I love the green color. I was a Kawasaki sport bike guy, so lime green is in my blood.
It's odd that, on the box (back), the stickers for the rear windows have a gap between them! As if the cars have a split back window like the early VW Beetles.
These things are a beauty. Would have loved to see a side profile, frontal shot, and direct rear shot in the review though like the other reviews. Nevertheless these sets are so outrageously high quality. I hope this theme goes on forever. It got me so interested in LeMans. Seriously why hasnt lambo join in???
Just the 911 turbo would be great! Maybe in yellow or red though. with "Fuchs" rims. ;)
By in Philippines,
NERD ALERT! NERD ALERT! NERD ALERT! NERD ALERT!
The two 911 RSRs depicted here are actually from the same generation, the 991. This version, in real life, had the engine and gearbox reversed, such that the gearbox is now on the rear axle where the engine used to be, in order to allow room for a bigger diffuser, which is reflected accurately in this model compared to the last RSR, which LEGO also has a model of. Great work, Mr. Callum.
I'll echo comments from above. I hope this theme goes on forever!
The source material for Speed Champions is nearly endless, and I can't wait to see what they continue to do. I will say that although I have steadily bought Lego sets over the course of my entire life, it is the Speed Champions line which brought me back to obsessive level MOC-ing and multi-set purchases to build up a parts supply. I really can't get enough of this line, and the advancement it has encouraged in building style and technique at Lego is really something to be proud of (Mr. Callum!). It has produced pure joy in my life year over year and just gets better and better with every wave. Thank you Lego, the Speed Champions team, and PLEASE keep them coming!!!
I am so going to get this set. Love the Turbo, which incidentally will go great with my Technic GT3 in the same colour.
And no, don't ask where I got a lime green Technic GT3. The answer might not be to your liking ;-)
The front of the green 911 is way too long. Move the windshield 1 stud forward and it'd look better.
