Review: 71741 NINJAGO City Gardens (2)
71741 NINJAGO City Gardens certainly appears impressive, including outstanding architectural variation and sensational detail. These features differentiated the previous models based upon NINJAGO City which have beautifully combined authentic and imagined architectures.
However, this model is significantly larger than 70620 NINJAGO City and 70657 NINJAGO City Docks, offering an opportunity to incorporate superior detail alongside varied references to the NINJAGO animated series and other LEGO themes. Part two of our review explores the completed model and those exciting references.
71741 NINJAGO City Gardens encompasses two baseplates, matching 70657 NINJAGO City Docks in that respect, while its spectacular height surpasses even 70620 NINJAGO City! This model measures nearly 74cm in height which exceeded my expectations and the tremendous spectrum of colours looks fantastic. Furthermore, I appreciate the continuing division between different periods of development as the uppermost structures are generally more modern than those beneath.
Perhaps the only notable criticism which is sometimes levelled at 70620 NINJAGO City is the relative dearth of detail across the reverse. Both subsequent models have definitely improved upon that and I think this example looks superb from either side, particularly because the new walkways stretch between the front and back. The entire cityscape therefore feels more easily navigable for its minifigure residents, with one apparent exception.
Despite the overwhelming density of modern buildings, evidence of NINJAGO City's history remains and this beautiful temple is an elegant example. The classic colour scheme of black and red looks marvellous, corresponding with various traditional buildings from the NINJAGO range. Moreover, I appreciate its stark contrast against the green island underneath and such vivid colours differentiate this model from its larger neighbours.
Two curved bridges provide access to the island, incorporating red wheel arch elements that appear suitably graceful. These are connected at unusual diagonal angles, a trend which will become increasingly prevalent as our journey through the city continues! Further to the bright colours mentioned previously, lovely flowers are also planted around the island and I love the pink lilies in the water too.
The central temple structure seems comparatively modest, although the golden highlights at each corner and the dramatically curving roofs are impressive. Additionally, I love the realistic texture on the columns and the consistent shapes between this temple and the accompanying bridges is appealing. The light bluish grey stonework on the ground looks similarly attractive.
Surprisingly, the whole temple can be removed to reveal a void underneath. The instructions make no suggestions regarding what could be placed inside, although the option for removal was seemingly intended. Regardless, more storage space is always welcome and I think this would be an ideal hiding place for mystical treasures, of which NINJAGO contains many!
Zane apparently sacrificed himself to vanquish the Overlord and his courageous action was commemorated by this titanium statue. The original statue is situated in NINJAGO Park and includes a sword on Zane's back, although this alternative location appears fittingly peaceful. Fun references to the television series, like this one, appear throughout the model.
The stone pillars behind this statue also correspond with the television series. Moreover, the island can be detached from the larger city using Technic pins. These are cleverly concealed inside the narrow light bluish grey piers which flank the statue and connect to a stone marker. An identical marker design appeared in 70657 NINJAGO City Docks and such consistency is appreciated.
Another small island is located beside that marker, providing enough space for some further foliage. The bush is familiarly assembled around a stem with six stalks but the tree is unusual, ingeniously incorporating green claws that were originally created for Wolverine! These convey an authentic windswept appearance. Even the tiny rock is represented by a dark bluish grey hat which appears quite natural.
Labyrinthine walkways connect buildings throughout the Old City. Their ramshackle aesthetic looks absolutely perfect and I love their varying heights, potentially indicating that these paths were historically adapted as new buildings were constructed. Of course, the designer has also ensured that these walkways match those from earlier NINJAGO City models.
The first shop we encounter displays a simple poster which advertises 'food' above an image of a steaming pot. The neighbouring serving window is exceptionally elaborate and I appreciate the traditional timber-framed design of this building, reflecting its age. The colour combination of reddish brown and white looks splendid, with dark blue doors.
Multiple structures throughout this model incorporate angled walls, including the food shop. Another poster is placed here and book covers create the simple awning above the second serving window. The texture across this wall is unique. Once again, this may indicate a long history as perhaps the building once connected to Ronin's pawn shop before changing uses resulted in their separation, leaving one mismatched wall.
This balcony is similarly interesting, extending immediately above the water. The distinctive wooden design looks superb and I like the small lamp outside the door, including a diamond which represents the bulb. Unfortunately, a conspicuous gap appears beside the hinges that support the aforementioned angled wall and that looks somewhat awkward.
Internal space is extremely limited, although the designer has definitely included impressive detail. Shelving with various ingredients occupies each corner and a sink is fitted on the wall, cleverly employing a 1x2 curved panel as the basin. There is even a printed dial beneath the stove that becomes almost invisible once construction is complete! In that regard, the design reminds me of 10243 Parisian Restaurant.
Removing this building reveals an underground pipe which is connected to the nearby water outlet. Such details are essentially superfluous but I absolutely adore them, particularly given how much room is available for hiding accessories around the pipe. The outlet looks excellent too, featuring a trans-light blue Power Blast which represents flowing water.
After collecting their food, minifigures might wish to sit on the nearby bench which is perfectly situated for looking out across the water. This bench can easily accommodate two minifigures and looks good, although I suspect its primary purpose was to disguise any untidy attachment points at the base of the tree. Twisted roots and foliage assist in this purpose, albeit restricting access to the bench.
These roots appear completely appropriate for an ancient tree and I love how bright green blades form different leaves. Some of these pieces are undoubtedly more successful than others, although I am particularly delighted with the smaller blades placed above the water. Furthermore, the flexible vine which wraps around the tree looks magnificent and the same technique appears in 10281 Bonsai Tree.
Despite being interconnected for strength, the leaves can easily become dislodged as each section is only attached using one clip. Nevertheless, they are unlikely to detach completely. Lime green and spring yellowish green are great colours for these elements and the latter is exclusively available here. The scattered lime green leaves and flowers look fantastic too.
The third branch stretches between the buildings and includes fewer leaves than those more exposed to sunlight. However, a bird has constructed their nest among these leaves and the round shape is formed using a reddish brown life ring. The resulting design looks lovely and surrounding structures ensure remarkable seclusion, given the urban environment.
Nature evidently occupies an influential role across 71741 NINJAGO City Gardens and this is reflected in its water, which lacks the pollution found around 70620 NINJAGO City and 70657 NINJAGO City Docks. Instead, the plates beneath the trans-light blue tiles are predominantly black or green, with the latter representing algae which accrues around the walkway.
Wedge plates are combined to form an elegant curve along the edge of this walkway and the open area between the buildings is excellent, providing ample room for displaying minifigures. This is only interrupted by a teal table which stands at the centre, including a soy sauce bottle with its distinctive red cap. Presumably this is intended for quick snacks, given the absence of seating.
Foliage continues around the outside edge of the stone path, where a pink frog also appears. That makes reference to Nick Vás who designed 70620 NINJAGO City and sometimes uses frogs throughout his models, including the recent 10281 Bonsai Tree. The neighbouring pillar seems fairly modern so stands out among the surrounding historic buildings. Presumably this was installed as the skyward construction of the city continued.
Ronin originally established his pawn shop in Stiix and that location was already depicted in 70732 City of Stiix. However, he now maintains another shop in NINJAGO City, although the design here hardly resembles his onscreen business. Nevertheless, the sand green and dark brown colour scheme looks fantastic, contrasting with the surrounding buildings.
The sign outside the shop is not written in Ninjargon, instead featuring letters from an earlier writing system which appeared during the animated series. Maybe this is Old Ninjargon. The sign may still be deciphered though and reads 'sale, pawn shop' beside Ronin's symbol. This stylised emblem also decorates an awning above the angled serving window.
Some buildings in previous NINJAGO City models have received criticism because they are difficult to access. Fortunately, this shop includes an enormous window which offers the best possible visibility for the internal details. The exterior looks splendid too though, featuring two golden party hats that form lantern supports with ornamental dragon carvings above the large window.
Numerous accurate details from the television series are found inside, including some lovely weighing scales which appear in both onscreen depictions of Ronin's shop. The famed Blade Cup trophy is placed on the floor, originally belonging to Cole's father before its acquisition by Ronin. The reddish brown cabinet against this wall also looks superb, featuring some drawers across the front.
Two golden trading cards are clipped inside the cabinet. These stickers are based upon the character cards which accompanied Spinners, with one representing 2175 Wyplash while the other depicts Spitta from 9569 Spitta. Furthermore, a map of the Dark Island hangs beside the door and the moustachioed disguise which is present onscreen returns here.
The golden trident also takes inspiration from the animated series and additional accessories are stored beneath the floor. They can be accessed by opening a trapdoor which reveals two bright green Jade Blades, several ingots and a trophy. We know that Ronin keeps trophies in stock because Dareth rushes to Ronin's shop after his fake trophies are stolen!
Removing this entire building reveals another hidden detail. This enigmatic box displays the phrase 'Easter egg' and an appropriate ninja hood with rabbit ears! The trans-green 1x1 tile inside refers to the original inspiration behind 70620 NINJAGO City, an amazing cyberpunk metropolis displayed by BroLUG at Brickworld Chicago during 2013. That creation included thousands of trans-green 1x1 tiles, hence one appears here.
Climbing the ladder from Ronin's pawn shop gives access to the tranquil 'Tea Time' balcony. Four traditional paintings are displayed here, imitating the style presented as Wu relates how NINJAGO was created during episode one of the Pilot Season. They include the initials of the set designer, Markus Rollbühler, beside those of a graphic designer, Kjeld Walther Sørensen.
The exterior includes an unusual window which inventively incorporates the light bluish grey brake disc that was introduced with 42107 Ducati Panigale V4 R. That slides neatly between reddish brown 4x4 curved tiles and the dark brown 2x2 tiles found at each corner prevent the brake disc from being pushed through the window frame completely.
Meandering pipework is fixed outside, effectively concealing the gap which inevitably results from the angled wall. Moreover, I like the green plant which is visible through the window and another two windows are covered with black shutters. These provide welcome variation to the model and I appreciate the continuing timber-framed structures.
Varied residences have appeared throughout 70620 NINJAGO City and 70657 NINJAGO City Docks. This example combines tan and reddish brown elements to good effect and features a trans-light blue NINJAGO sign outside. Unusually, the text on this banner features the Roman alphabet, rather than Ninjargon that appears elsewhere.
Windows of varying size surround the apartment and I like the black awning which comprises ten 1x3 jumper plates, fixed upside down. The golden window underneath appears especially ornate and colourful flowers are displayed outside. This entire apartment is significantly larger than the building underneath, projecting over the stone walkways at ground level.
Nevertheless, interior space is relatively limited and reaching inside to position minifigures is rather difficult. The detail is impressive though, featuring several small renditions of NINJAGO sets. They include 71747 The Keepers' Village and 71748 Catamaran Sea Battle over the bed, 71746 Jungle Dragon on a nearby cabinet and 71737 X-1 Ninja Charger on the floor!
Additionally, this minifigure owns NINJAGO-themed bedding which looks absolutely brilliant. Black and red ninja adorn the stickers, both of which are clear-backed and can be applied to elements of any shade, although teal pieces are provided. Removing this bedding reveals an intriguing space that houses a sai, presumably for defending against the repeated attacks on NINJAGO City!
The opposite wall includes a white figurine which might represent Zane, given the consistent NINJAGO theming, beside a poster advertising NINJAGO City. This poster was available with purchases of 70620 NINJAGO City during 2017 and later returned on another sticker in 70840 Welcome to Apocalypseburg! While that example was tan, this sticker is white.
Unfortunately, the NINJAGO fan apartment includes no proper access points for minifigures, unless they leap through a hole in the floor. The shop underneath is certainly small but there would have been sufficient room for a ladder, like that found in Ronin's pawn shop. Moreover, there are no staircases or lifts linking the Old City with higher levels, unlike in previous sets.
Another integral feature of past NINJAGO City models are their elevated walkways and they continue here. However, this configuration is unique as Chen's Noodle House is not actually attached to the walkway, allowing easy removal and revealing another small model which is suspended above the apartment. This creation depicts 70688 Jay's Storm Fighter.
Numerous advertisements are distributed around the railings, corresponding with earlier sets and displaying myriad references. The first two billboards feature the icons from Clikits beside letters that read 'M.A. Fashion' and make reference to Matthew Ashton, LEGO's vice president of design. An aquarium and chilli house are advertised on the next railing, perhaps suggesting businesses for another expansion to the city.
This protruding segment of the walkway is only fixed using Technic pins so can be detached easily when connecting this structure with its predecessors. The table outside Chen's Noodle House remains in position though, under a poster which advertises the 'new parmo'. This dish originates from the North East of England and periodically appears on sets designed by Justin Ramsden.
Continuing along the walkway, Rock Raiders is advertised next. This memorable theme was available during 1999 and 2000 and teal highlights decorated several of their vehicles, hence the colour seems appropriate here. The emblem for Model Team appears on the neighbouring yellow sign beside a banner which refers to Bolobo, the Elemental Master of Nature.
Chen's Noodle House was introduced during the Tournament of Elements and is among the best restaurants in NINJAGO City, as boasted on the poster outside the door. The bright red columns look wonderful but my favourite exterior detail is undoubtedly the distinctive mascot which originates from the animated series, albeit carrying two bowls on this occasion.
The mascot is mounted using standard minifigure legs so does create a complete minifigure, with exclusive torso and head components. Additionally, the roof behind this mascot features tremendous detail, comprising numerous black sausages and 1x1 clips. The resulting texture looks remarkably realistic and unlike anything found in previous sets.
Befitting its position within the city, Chen's Noodle House combines traditional timber framing with modern windows. That architectural style corresponds with the onscreen location and the floral window box outside looks marvellous, matching flowers on the level below. Additionally, I like how dark bluish grey landing skids are employed to form industrial details.
The internal space is restricted when compared with the original restaurant, although several important features are included. The colourful signage above the counter is especially familiar and promotes the availability of sushi, shrimp bowls and ramen. Fitting a minifigure behind this counter would be extremely difficult but the designer has cleverly integrated hinges which allow the whole assembly to swing aside.
Opening this section of the noodle house also provides easier access to the customer area. Unfortunately, there is only enough room for one table, although this is neatly furnished with another soy sauce bottle and a bowl. The decoration above this table looks excellent as well, betraying Master Chen's evil obsession with the powerful Anacondrai.
The competing crab restaurant from 70620 NINJAGO City is advertised outside and the next billboard reads 'Znap' so makes reference to the infamous LEGO theme! The emblem beside this Ninjargon word depicts a Znap connector. Several pearl gold pieces comprise the elegant decoration at the corner of this walkway, including a conical hat and armour components from the recent Prime Empire subtheme.
This design appears considerably more elaborate than its counterpart from 70620 NINJAGO City, further reflecting the attractive environment of 71741 NINJAGO City Gardens. The large tree that grows between different levels maintains that trend, again combining lime green and spring yellowish green foliage. The tree also includes a printed 2x2 round tile to celebrate the tenth anniversary of NINJAGO.
Further billboards display the font and colours on Tim's torso from Time Cruisers, the Time Twins' symbol, the Prime Empire branding and another advertisement for 'AO5 Renovation'. This obscure decoration makes reference to the code assigned to retired LEGO elements, rendering them unavailable for designers to use. Trans-light blue lanterns are fixed along the railings, varying from the trans-neon orange fixtures which have accompanied past NINJAGO City sets.
Nevertheless, these lanterns look great and I love the golden adornment outside the Ice Planet ice cream shop, which is designed around a snowflake component. The colour scheme of dark azure and dark blue seems somewhat inconsistent with Ice Planet 2002 that inspired this shop, although these shades look superb together and I think including any trans-neon orange would have overwhelmed the other colours.
The signage above the ice cream shop looks splendid, reading 'Ice Planet' and displaying an attractive logo which corresponds with Hai's uniform. However, the most enjoyable details are certainly the roof tiles. They are ingeniously constructed using layered cleavers while skeleton arms support the roof from underneath, appearing perfectly realistic.
Once again, the interior is reasonably cramped but that appears more appropriate for this ice cream shop than for Chen's Noodle House. The serving counter includes some striking trans-orange details and I like the sticker that shows various ice cream flavours behind the counter. Dark orange and tan ice cream cones are also situated here, along with multiple glasses and 41906 Pineapple Pencil Holder on the shelf above!
The available ice cream flavours are displayed opposite the counter, including a bright orange ice lolly which corresponds with the Ice Planet 2002 theming. The ice cream placed below this advertisement conveys the essence of Ice Planet 2002 even more successfully, combining the three vivid colours most associated with that popular subtheme.
An appealing balcony occupies the space immediately behind the Ice Planet ice cream shop, featuring a dropped ice cream cone! Details like these distinguish each NINJAGO City model from anything else which LEGO releases, in my opinion. The awning above the door includes undecorated video game controllers which look brilliant and I love the realistic air conditioning unit located on the balcony as well.
Minifigures can access the next floor by climbing the staircase beside the ice cream shop. A yellow sign directs visitors to the museum by following these steps and another poster reads 'yummy', proclaimed by the shop's penguin mascot. Naturally, this penguin is shown wearing distinctive equipment from Ice Planet 2002, including a trans-neon orange visor.
Corresponding with Chen's Noodle House, the Ice Planet ice cream shop can be detached separately from the walkway. Unfortunately, the void underneath is completely empty which seems like a missed opportunity as there would have been sufficient space for some further references to Ice Planet 2002, perhaps including miniaturised sets!
The walkway outside the NINJAGO Museum of History appears more elaborate than those downstairs, featuring black handcuffs which form impressive decoration. The accompanying flowers look magnificent too. However, I think the museum seems comparatively bland when viewed from this angle, primarily comprising substantial wall panels and rectangular windows.
Fortunately, this structure includes superior detail across the front. The trans-pink sign which advertises the Dragon Grill appears especially attractive and the intertwined Ninjargon letters also look excellent. Furthermore, I like the dark red sign which presumably promotes the crab restaurant from 70620 NINJAGO City, given its colour and the inclusion of a crab.
Differentiating this model from 70620 NINJAGO City must have presented some challenges, particularly because both structures share similar layouts. The inclusion of a dramatic angled wall seems accordingly effective, contrasting with the curved window on the other model. The flame yellowish orange and teal colour scheme is equally distinctive and the red roller coaster track component looks marvellous, nestling behind the tree.
This museum is based loosely upon the NINJAGO Museum of History which appears several times throughout the animated series. While the colours and location are notably different, the unique curving skylight is accurate and looks absolutely fantastic. Flame yellowish orange tails from Unikitty are positioned around the skylight and the resultant shape looks great.
The trans-clear 4x4 curved panels which form the primary window are not actually attached using studs, although it feels rather secure between the flame yellowish orange structures at each end. Additionally, an imposing skeleton hangs inside this skylight, featuring lovely detail and seemingly inspired by the Skull Sorcerer's skeletal dragon, known as Grief-Bringer.
Before exploring the museum exhibits, minifigures must inevitably pass through the gift shop which features a postcard stand. Several printed tiles are placed around the display, including examples from DOTS and Minecraft. However, the tiny 70751 Temple of Airjitzu is undoubtedly my favourite detail, cleverly incorporating a sausage to form the recognisable bridge with fitting colours on each building.
Despite the restricted room inside, the designer has provided a simple counter with a rotating turnstile and two portraits are displayed over this counter. One depicts Helena Tova Skvalling from Pharaoh's Quest while the second is inspired by Niels Milan Pedersen, the adventurous designer of various memorable sets and the primary basis for Johnny Thunder! The powerful Realm Crystal is also included, beneath a glass dome.
Continuing inside the museum, exhibits include an ancient map which features an interesting land formation that differs from NINJAGO. The shaping is somewhat reminiscent of onscreen maps, although their designs have proven rather consistent. The neighbouring painting of the Great Devourer is immediately recognisable though and I like the style of these artworks.
Another portrait seemingly depicts Yang, given its position which corresponds with Day of the Departed. However, the light bluish grey beard and white clothing appear more reminiscent of Wu. Furthermore, the golden weapon beneath the painting hardly resembles the infamous Yin Blade. The display case looks spectacular though, neatly comprising a reddish brown treasure chest and a trans-clear window element.
Trans-clear minifigure stands are distributed along this wall, representing the spotlights often found in museums. These details appear perfectly realistic and another portrait hangs beside the window, accurately portraying Ray and Maya. An identical painting appears in the original museum during the television series, even featuring exactly the same backdrop! Artefacts are also displayed in the next cabinet.
Removing the aforementioned diagonal wall provides easy access to the museum, revealing further details inside. An outstanding rendition of the Destiny's Bounty is displayed on a trans-clear plinth and an elegant Serpentine staff occupies the next pedestal. The original staff was retired after 2016 but this alternative looks good. Moreover, I love the dramatic painting of the conflict between the Elemental Masters and the Hands of Time.
This painting undoubtedly resembles its onscreen counterpart, although the dragons appear incongruous. Nevertheless, the colours are perfect and the frame reflects the source material too! The artwork is only attached using one stud and removing the painting reveals an uneven hole through the wall. Numerous incidents have occurred at this museum during the animated series, hence such damage is decidedly unsurprising.
Another impressive image covers this hole from the outside, advertising Mega Monster Park which makes several appearances throughout the television series. Rides appear behind the titular monsters and I appreciate the shared colours between this poster and the painting that occupies the other side of the museum wall. Unfortunately, viewing the poster properly requires partially disassembling the neighbouring apartment.
Alternating bright green and sand green tiles decorate this apartment, providing an additional splash of vivid colour to this model. Such bold shades would not be suitable everywhere but I think they look excellent here, especially in combination with pink flowers in each window box. These make interesting use of the teal skirt element introduced for Trolls: World Tour last year, creating an unusual shape.
Despite occupying an even smaller space than the NINJAGO fan apartment downstairs, this residence is nicely furnished. The bed is immediately recognisable and I like how a dark blue shoulder armour component supports the plant growing on the window sill. Gayle Gossip from NGTV appears on the television and two jars of paint are hidden under the bed.
Viewing this building from the other side reveals an easel which displays a brilliant painting of 71741 NINJAGO City Gardens. The colours look marvellous and I like the paint brush clipped on top. An umbrella stand is also included beside another 41906 Pineapple Pencil Holder that suits the artist's apartment. Of course, neither home features any kitchen or bathroom facilities but I think that would have been impossible without increasing their size.
The balcony which connects to this apartment appears ideal for painting, presumably giving panoramic views of the city. The plants on this balcony look splendid and I like the steps that lead from the door. Unfortunately, the structure feels fragile when detaching this balcony from the apartment, although the ingenuous use of pantographs to form railings is enjoyable.
Reaching the rooftop garden requires considerable agility and climbing ability because this ladder seems exceptionally basic. Admittedly, the ninja could easily accomplish such a task, although a more substantial ladder could have been provided. Minifigures must also clamber over the pearl gold railing which feels completely unsafe, except for the ninja!
Minifigures could also employ flying vehicles to access the rooftop. This medium azure hover bike is designed around the standard scooter frame but looks fantastic, due in particular to the white fence piece which supports the engine nacelles and stabilisers. Trans-pink jewels provide an appropriate engine glow and the bike is attached using a trans-clear stanchion which seems effective, as usual.
The rooftop Zen Garden features an elegant pavilion that consists predominantly of lavender bricks. Curved steps provide easy access to the pavilion and the ornate fences on either side appear perfect for this serene environment. In addition, this roof features beautiful texture that comprises ten treasure chest lids which are connected using clips, creating an uneven design.
Opening the roof reveals two roller skates beside an orange Classic Space helmet, although I expect this is supposed to depict the Thunderblade helmets from the Tournament of Elements here. The designer has also provided a safe, containing a teal 1x1 slope. This could represent traveller's tea but actually reflects Markus Rollbühler's routine use of colourful 1x1 slopes in his own fan creations.
Plants seem noticeably absent from the Zen Garden, although this cherry blossom tree looks sensational. The pronounced curvature of the trunk is appealing and I love the colour scheme which comprises lavender and white leaves, with pink flowers and magenta cherries. This tree forms part of the museum skylight and prevents minifigures from walking across the rooftop to reach additional buildings.
Instead, they must travel back along the walkway on the level underneath, reaching a ladder which can be deployed by rotating this Technic gear. The mechanism is exceptionally smooth and I think the ladder extends sufficiently for the ninja to gain access. Lowering the ladder also reveals the entrance to the Ninja Zone, where the heroes can relax between missions.
Three different movie posters may be displayed beside the ladder, making reference to noted LEGO themes. The first is based upon Space Police III so features stylised depictions of 5981 Raid VPR and 5983 Undercover Cruiser, alongside the alien Rench and a Space Police officer. Each poster is nicely secured using a 1x1 curved plate with clip and adjustable lights illuminate them from below.
Another poster takes inspiration from Adventurers and reads 'Adventure Island, coming soon'. The male character definitely resembles Johnny Thunder and the Jungle Explorer from Series 19 of the Collectable Minifigures. The final billboard reads 'Terror Aquasharks' and accordingly displays an enormous robotic shark! This title refers to the villainous Aquasharks faction which appeared in the Aquazone theme between 1995 and 1998.
This entertainment centre is named the Ninja Zone and is ideally suited to the ninja, including numerous video games while also providing an excellent view of the city, should their skills be required suddenly. The colour combination of teal and dark bluish grey looks brilliant and I like how angular spectacles from 41597 Go Brick Me form modern barriers surrounding this space.
Prime Empire was introduced during 2020 and appears on the television, displaying a sinister Red Visor beside another character carrying a Keytana. An arcade cabinet is supplied as well. This game is named 'Street Ninja II' and includes an incredible function as moving the joystick actually causes the ninja on the screen to jump, while the Great Devourer remains unmoved.
The function is remarkably simple as the pixelated ninja adorns a 1x2 tile behind the screen. Nevertheless, I appreciate this unusual feature, especially as the outward appearance of the arcade cabinet is not affected. The primary characters appear together in a photo beside this machine but Kai is noticeably excluded which seems strange.
Animal-themed advertising mascots have appeared in both 70620 NINJAGO City and 70657 NINJAGO City Docks. This majestic koi carp features excellent orange and white stripes and incorporates tremendous detail, notably including realistic barbels and pectoral fins which are depicted using orange leaves. Presumably the mascot refers to the aquarium which appeared on an earlier sign, although its connection to the wall could potentially have been strengthened.
Teal becomes increasingly prevalent across the tower which stands atop the Ninja Zone and several 8x6 wedge slopes form distinctive diamond shapes. They definitely stand out against the traditional pavilion which appears nearby, although these windows are consistent with the Zen Garden. By contrast, the trans-pink hexagonal flags on the uppermost floor appear totally modern, slotting precisely between the wedge slopes.
Removing that segment of the tower reveals a hidden chamber where Jay's gi is kept, along with the unused movie posters. Previous models from the NINJAGO City series have offered clever storage solutions for similar billboards and I am delighted to encounter another distinct method here. The minifigure storage is appreciated as well.
Further to their Elemental Powers and Spinjitzu skills, the ninja also rely upon technology to support each mission. This control room is therefore welcome and looks fairly reminiscent of Oracle's clock tower headquarters from certain Batman comics and video games. Pythor and General Cryptor are each displayed on the screen beside a map of NINJAGO. The message underneath reads 'alert' in response to these villains' reemergence.
The communication tower immediately above the control centre is comparatively fragile and removing this structure to access the interior is accordingly difficult. The dishes look splendid though and I love the repeatedly changing angles of every tier. Once again, these shapes are unlike anything found throughout previous NINJAGO City models, ensuring that these appear realistically diverse when combined.
70620 NINJAGO City and 70657 NINJAGO City Docks are widely discussed among the best modern LEGO sets and considerable expectation accordingly followed their successor, 71741 NINJAGO City Gardens. Fortunately, I think the model is absolutely incredible! The details and creative construction methods are unmatched, even by those previous sets in my opinion.
The layout of NINJAGO City Gardens is especially successful, generally avoiding the awkward navigational issues which have affected both earlier sets. The absence of steps to connect the Old City with the modern street above is slightly disappointing, although including those would require losing something else on each level. Personally, I am willing to forego such features in favour of greater detail.
In fact, I think the only area with significant potential for improvement is the minifigure selection. Providing additional characters from the television series would certainly have been welcome. Nevertheless, the price of £274.99 or $299.99 represents fantastic value and I would highly recommend 71741 NINJAGO City Gardens. This set encapsulates the fun, imagination and true artistic potential of LEGO.
The final part of our review, combining 71741 NINJAGO City Gardens with 70620 NINJAGO City and 70657 NINJAGO City Docks, along with 80107 Spring Lantern Festival, will be published shortly. The range of possible combinations is surprising!
67 comments on this article
As suggested in the comments from part one, I have included an interloping animal in one photo. However, porgs did not seem at home in NINJAGO so I chose another animal which evidently exists within the NINJAGO universe.
The pink frog, bird and husky are included with the set so the mystery animal is something else.
Good luck with the search!
wow. amazing set! mines still in Belgium.....
I cannot find the goat...
Great review, thanks alot! Absolutely an amazing set, but a little tendious build sometimes.
My personal favourite of the three is still 70620 Ninjago City with a good margin and this 71741 Ninjago City Gardens on the 2nd place. (Sorry Docks..)
Pink frog!
best set of all time. so cool in person!
really appreciate the time and effort you are putting into these reviews!
and still another to come?
thanks cap'n!
Wow! Worth the wait.
Although I'm reading this more as an Easter egg guide than a review. ;-)
Mines in Belgium but hopeful it’ll be shipped this week, is the pink frog meant to be there or is that the animal you’re suggesting is the interloper
Transparent pieces look so milky and ugly now :(
There is so much incredible detail packed into this set, I absolutely love it. I absolutely do not regret making it a day 1 purchase! (Not that I expected to, of course :P )
On the last picture, the husky out of 21325
This set honestly looks amazing and is definitely going to be an imminent purchase. Especially given I regrettably missed out on Ninjago City and docks.
Strong candidate for best set of 21, even though were not even halfway in yet.
@Everylittlebrickhelps said:
"Mines in Belgium but hopeful it’ll be shipped this week, is the pink frog meant to be there or is that the animal you’re suggesting is the interloper "
The pink frog comes with the set, and mine is also still stuck in Belgium. They’re taking they’re time....
No sloths are included in this set.
These huge Ninjago sets are so incredibly designed!!! I wish LEGO would design similar large and intricate sets for other themes such as Star Wars or Castle
I’ve looked over all the images at least 4 times, and I’ve now decided that I must be legally blind. Can we know what we’re even looking for? Any hints?
WOW! Building this set should be a total BLAST!
I think im first to notice this. But ninjago fan room has two biggest newest sets on upper shelf. The village and 2 catamarans!
This is first set to include A SET REFFERENCE before original hit the shelves!
I don't see any sloths there.....
@CapnRex101 said:
"As suggested in the comments from part one, I have included an interloping animal in one photo. However, porgs did not seem at home in NINJAGO so I chose another animal which evidently exists within the NINJAGO universe.
Good luck with the search!"
I wonder if it's the small black bird (pigeon ?) on one of the last pictures ? At the foot of the satellite tower...?
I’m not going to spoil it for anyone else, but I’m fairly sure the interloper in question is peeking out behind the tree if you want a hint.
The little island looks like my dojo in Warframe.
LEGO needs to learn how to properly bring back Adventurers and Space Police.
@FreewheelBricks said:
"I’m not going to spoil it for anyone else, but I’m fairly sure the interloper in question is peeking out behind the tree if you want a hint."
You're so right. I thought these kinds of animals lived further to the south, but who knows where Ninjago City really is located...
I read somewhere in the past few weeks that trans neon reddish orange has, or is just about to be, retired from use. That might explain the inaccurate colors on the Ice Planet 2002 ice cream shop.
This looks like a completely brilliant set. It didn't strike me the same way as the original Ninjago City did from the initial pictures, but my appreciation has tremendously grown by seeing all the detailed interiors, cleverly angled walls, and hidden compartments. A functioning arcade machine is one of the smartest little features I've seen in any LEGO set in a long time... that display case made by connecting a window to a treasure chest is unbelievable. I had no idea those parts went together like that.
I have no interest in Ninjago or its story, I wouldn't want to display this as I have no space and the aesthetic wouldn't fit
But
I really want to build this. There's so many interesting pieces and building techniques and details. It's clear a lot of love has gone into it and maybe a bit of self-deprecation (ZNAP and Clickits references!).
^ I was wondering about those Space Police III links, too. I have no interest in Ninjago, but again TLG creates a superb set! And what an excellent review, Capn! As always! I still think 70620 NINJAGO City is better. I can’t put my finger on it, but this set is very good. It’s superb ... but short of excellence. It lacks an “umph” or “wow” factor for me. That first NINJAGO City set is still the greatest of all. It is more interesting with its color, creativity and NPU, and has its surprises.
@CapnRex101 said:
"(...) However, porgs did not seem at home in NINJAGO (...)"
It'll be a hungry visit to NINJAGO City for Chewbacca.
@Paperdaisy said:
"I have no interest in Ninjago or its story, I wouldn't want to display this as I have no space and the aesthetic wouldn't fit
But
I really want to build this. There's so many interesting pieces and building techniques and details. It's clear a lot of love has gone into it and maybe a bit of self-deprecation (ZNAP and Clickits references!). "
Just an aside, but if you haven't tried building digitally with programs like Mecabricks or Stud.io, I've found what you described to be a great use of them. For my part, I do collect Ninjago sets—but I'll occasionally build a set that's farther outside my wheelhouse like a Star Wars or Super Heroes set just to get a feel for them and maybe learn some tricks I can apply to my own MOCs. None of the programs I described are perfect (especially when it comes to the selection of newer or more specialized parts, which can take time and hard work on the part of fans to get added to the software), and it's certainly not going to provide the exact same experience as building a set physically with your own hands, but that's not to say that nothing can be gained from it.
My order is also sitting in Belgium still and I'm trying to not get too impatient, given that I'm not going to be able to build it, even when I do receive it!
However, when I have sorted space out (some day), I'm going to build all three sets for the first time, at the same time. Bag 1 of each, then bag 2 etc. etc. I really can't wait to start that project! :-)
These two reviews have been fantastic though and I can't wait to read the final installment!
Looks like the interloper is from the Ice Planet. Great review.
Maybe should’ve put a spoiler alert at the top of the review for those wanting to discover some of these things themselves.
@Greshi:
One species lives in an archipelago that straddles the equator. Very few live where you're probably thinking.
I liked the other two sets, but this one is a bit too messy and noisy for my tastes. The dock is easily my favorite of the three.
Wow, this set looks amazing... I love all of the Ninjago easter eggs. This may be my favorite set of this size I've ever seen. Thank you for the review!
@jaredhinton said:
"Maybe should’ve put a spoiler alert at the top of the review for those wanting to discover some of these things themselves."
I did mention that the review would discuss the various Easter eggs and references during the introduction, as I think one might expect.
@jalc_45 - Thank you spotting the incorrect link. As you mentioned, it has now been fixed.
That’s not a chicken!
I feel like I must be missing something, because I cannot spot the animal interloper
The shark on the poster is like you said Aqua Sharks but to me the shark is more like the one from Ultra Agents set 70172.
Does anyone else agree.
By the way I found the hidden animal without any hints, I’m surprised that you picked that animal to use.
When I found it, it kind of creeped me out for a second, thankfully not as much as “My Dad”.
Will you continue to hide it in your future reviews or was it a one timer thing.
Thanks for the great review, keep up the great work.
I absolutely love this set, but after this review I think I like it just a little bit less than the original two. It definitely stands out thanks to all the angles and bright colors, but even though there are more areas to explore than the previous sets, I feel like there's less to do. Some of my favorite features of the original sets are absent here, like the awesome working ATM and vending machine builds, and I think the lack of consistency with small things like the lantern colors is strange. I really wish there was easier access for minifigures between levels as well, since with LEGO's suggested configuration of all three sets, the characters would have to backtrack all the way to the Docks in order to reach the street level. I think I'm just a bit disappointed by the interiors because they seem smaller and more cramped due to the angled walls. However, there's some fantastic added functionality here with the walls that can swing out and the street-level buildings being removable, and of course the quality of the design is still fantastic. I can't wait to see the different connection options!
@CapnRex101 said:
I did mention that the review would discuss the various Easter eggs and references during the introduction, as I think one might expect."
Not being argumentative, but you didn’t mention Easter eggs in the opening and references isn’t clear enough that you’d uncover all the secrets including, translating the stickers, in the set. Just think an overt “Spoilers will follow” warning may have been polite.
Again, not meaning to be an ass about it. You’re article was actually awesome and helped me understand a lot of things I knew I was missing because I don’t have the kind of Ninjago history knowledge to get it all, so I really appreciate all your research. Designing the set mustve been a labor of love and it’s clear your work deciphering it all was driven with just as much passion, so thanks so much.
Sooo many details, it's blinding...
"How many references do you want to put into this set?"
"Yes."
By in Serbia,
I spent a lot of time looking for the cameo critter and couldn't find it :(
Absolutely awesome, still need to build mine
For those who are interested in the sticker translations:
I translated all of them and even replaced the text on the sticker scans.
Along with some additional notes you can find them here now:
https://roguebricks.de/71741/
@Vaionaut said:
"For those who are interested in the sticker translations:
https://roguebricks.de/71741/"
Very well done!
Epic reveiw, Captain! Thank you - there’s a huge amount of effort and research gone into that article - much appreciated.
Kai doesn’t need to be in the picture; he already has more set appearances than any of the other ninja.
Fantastic review of an amazing set, thank you! Such an incredible amount of detail throughout, including the interior of course, and so many great building techniques and part usages, like that skirt turned upside down for a window box... Just wow.
Any chance at all that this could hint at a coming Adventurers set? Considering that the designers seem to really like easter eggs
This is another glorious set released this year, it's hard to get all of them....
@Legonk said:
"> Another poster takes inspiration from Adventurers and reads 'Adventure Island, coming soon'.
Any chance at all that this could hint at a coming Adventurers set? Considering that the designers seem to really like easter eggs"
If true then I WANT SOME OR ALL OF THEM!!!!
Why would you read a review if you want to discover the secrets for yourself?
Lego is a way to transport us to worlds that cannot exist, and this is one of them. It is this principle that makes this series more compelling than Modular Buildings.
Wonder if there will be 10th anniversary friends sets ; )
For parts usage...the Lego designers must have bets along the lines, "I bet you cant use this part for anything else". This set made use of many. There were recolored skeleton torsos, feet from Mario creatures, minifig hats, and many more put to creative use. Has been an amazing build. Thank you for pointing out all the call backs and Easter eggs. Great couple articles
"I like the red flower placed outside the door."
I believe that the 'flower' outside Ronin's pawn shop is an ingeniously-constructed water spigot! Great review, very detailed set, I hope against the odds that the Adventure Island poster is a teaser for something 'coming soon!'
Picked up the very last copy at the Nashville Lego store. This is now the largest (in terms of piece count) set in my collection. I'm going to have my kids assemble as they are still in sham school and then likely disassemble to use in MOCs. Even as a long time Ninjago fan I have never purchased any model in this theme before this set. And I didn't think I would purchase this one- particularly at this price point. But the set is so awesome it kept popping into my mind and then this review just pushed me over the edge. Box is HUGE and I'm excited!
I spy with my eyes..... a sneaky little penguin peeking around the corner of the tree in the picture showcasing the Ice Planet Icecream Shop's backside ;)
By in South Africa,
I spy with my eyes..... a sneaky little penguin peeking around the corner of the tree in the picture showcasing the Ice Planet Icecream Shop's backside ;)"
Bless you sir. And I spent more time searching than I should have, so I do not consider this a spoiler anymore.
Thank you, I was going mad trying to find it
awesome NPU in this build.
hahaha that penguin! hilarious!
A fabulous set.
Which is now on my wanted list as a top priority.
I am impressed by the detail of the review and the knowledge of the reviewer.
