Review: 75576 Skimwing Adventure
LEGO launched the impressive Avatar theme in 2022, featuring a variety of incredible creatures from the original film. The theme has expanded to encompass ocean-dwelling animals this year and the appealing style established in previous sets remains.
75576 Skimwing Adventure seems attractive in particular, capturing the grace of these creatures onscreen. The slender shape and appealing colours definitely seem accurate, while the exclusive minifigures represent an exciting bonus!
75576 Skimwing Adventure , 259 pieces.
£29.99 / $34.99 / €34.99 | 11.6p, 13.5c, 13.5c per piece.
While overpriced, the skimwing looks absolutely beautiful in LEGO form
  • Accurate shape and colours
  • Excellent articulation
  • Great minifigures
  • Gaps along the body
  • Quite expensive
Avatar: The Way of Water introduces the ocean-based Metkayina clan, ruled by Tonowari. The character's complex facial tattoos look superb and I like the medium azure skin tone, separating members of the Metkayina clan from the jungle-dwelling Na'vi encountered previously. Also, this version of Tonowari is unique, lacking the necklace he wears in 75578 Metkayina Reef Home.
Jake Sully also includes an exclusive torso and head, differing from the minifigures available in sets originating from the first Avatar film. I like the dark green and metallic silver pouches across his chest, alongside a curved knife which has appeared on two of Jake's earlier figures. Metallic silver speckles decorate the head as well, while the yellow eyes stand out brilliantly.
Both minifigures feature the same hair element, capturing marvellous texture and only otherwise available in the bigger 75578 Metkayina Reef Home. Moreover, the trans-light blue spearheads on Tonowari's weapon are equally uncommon, while Jake is armed with a standard crossbow.
Pandora is home to countless stunning animals and exploring the oceans in Avatar: The Way of Water has introduced many more. These include the skimwing, an elegant flying fish which can move comfortably through water or air. The slender shape of this LEGO rendition looks fantastic and measures 33cm in length, so provides remarkable presence on display.
The head comprises two elements developed specifically for the skimwing, creating an accurate shape. The elongated jaw and rows of teeth look superb, while the colour scheme is splendid as well, particularly with the dark blue patterns on top. However, another instance of dreadful colour matching occurs between the lower jaw and the tan printing near the back of the head.
As expected, the jaw opens and reveals even more moulded teeth inside. The head is mounted on a ball joint, which provides a good range of motion in all directions, while the two pectoral fins are also adjustable and represented by flame yellowish orange flags. The gap between the head and those fins is very noticeable, but was indispensable for articulation.
Many Pandoran species feature neural queues, which are tendril-like appendages allowing them to mentally link. The skimwing integrates two flexible queues and either can be connected to the Na'vi minifigures, as shown below. The minifigures' prone position appears reasonable, but they should have been able to stand up as an alternative.
Like the winged animals in other Avatar sets, the skimwing includes flexible plastic wings, which are beautifully decorated. The orange, flame yellowish orange and black patterns are absolutely stunning, with sand blue accents matching the skimwing's body. Furthermore, the four wings are attached using Technic pins and click hinges, each providing comprehensive articulation.
The body incorporates three points of articulation too, with a rotational joint allowing the forward section to twist or move up and down. A ball joint permits similar motion behind the wings, while a simple click hinge allows the tail to swing sideways. In combination, these joints provide many options for display, although the segmented construction creates inevitable gaps.
Avatar sets are known for their clever display bases and 75576 Skimwing Adventure maintains this trend. The creature rests on a Technic pillar and a hexagonal section of the seabed provides ample stability. Another base is provided for a minifigure and both are very colourful, featuring a variety of blue and purple shades, with sand green and coral. Similar colours are shared across the Avatar: The Way of Water range.
Skimwings are perhaps my favourite of the animals introduced in Avatar: The Way of Water and 75576 Skimwing Adventure certainly captures their graceful appearance. The superb articulation is essential, alongside a beautiful colour scheme of sand blue, tan and various shades of yellow across this ocean creature.
The poor colour matching on the head is disappointing and the numerous joints create unsightly gaps, but the design is otherwise excellent. The minifigures are good too, leaving only the price of £29.99, $34.99 or €34.99 as an issue. Unfortunately, that price does seem expensive, so I am pleased that discounts have already begun because this is an enjoyable set.
22 comments on this article
What happened to Pros and Cons lists at the top?
@SD449 said:
"What happened to Pros and Cons lists at the top?"
I forgot to add it, but have done now. Thanks!
By in Luxembourg,
Look at those head prints, and then look at the official pictures, box etc. This is straight up lying, LEGO. The quality is moving further away from the prices and this is just shameful.
That printing quality might just be among the worst they ever did...almost makes you long for stickers (as if those would match....)
Also, why the red red Technic pieces underneath the wing? I get the orange and black ones, those match the vinyl piece quite well, but those red? Well, at least they don't try to hide them on the box...
Apart from that a nice set, a bit overpriced but not too bad.
Even as a child, I never knew how to play with the "underwater" Lego sets, and they're still weird to look at these days. I could deal with ground level and air level sets, but not these. There's something unnatural about them to look at and I never knew where to place them when playing on the floor as a ground level. I find the Harry Potter Triwizard Tournament one to work well though.
The dragon's wings could be used to MOC a nice butterfly.
I don't get the color match issue. They have to test it, right?
If it comes out wrong, adjust the color and reprint?!
While this set isn't cheap, the entire set is like priced the same as 1 Brachiosaurus.
I take creatures like this over JP dinos any day, even with this using special heads etc.
@TeriXeri said:
"While this set isn't cheap, the entire set is like priced the same as 1 Brachiosaurus.
This is a very good point, and the difference between price and value. And although value can be subjective, I feel that most new sets lost value more than they raised prices.
What I’m wondering is how, after more than two months since it’s release, BrickLink hasn’t cataloged the minifigures or part inventory for this set and 75578.
LEGO owns the website. Surely it shouldn’t take two weeks, let alone two months.
The same thing happened with the 75331 Razor Crest. Took months for the inventory to be made available.
@Bricky_Dee_Williams said:
"What I’m wondering is how, after more than two months since it’s release, BrickLink hasn’t cataloged the minifigures or part inventory for this set and 75578.
The same thing happened with the 75331 Razor Crest. Took months for the inventory to be made available. "
Inventories are contributed by the community, Lego's are not good enough for bricklink's use.
@sipuss said:
"Look at those head prints, and then look at the official pictures, box etc. This is straight up lying, LEGO. The quality is moving further away from the prices and this is just shameful."
Absolutely.
LEGO needs to be called out for their behaviour of blatant lying and false advertising.
The difference between the depiction of their supposed print quality on boxes and marketing materials versus what you actually get is just as annoying as the difference in terms of transparent pieces.
None of their box images or marketing beauty shots have ever shown the milky material they now use and which is just as cheap as it looks. It's no wonder that knockoff companies used to use this material widely. When I bought the Lepin Green Grocer clone years ago the only dead giveaway that it wasn't real LEGO were the milky transparent pieces. I even made a point back then to order replacement pieces on Bricklink to swap them out and make the thing look "proper". Nowadays there's no need since official LEGO now looks just as cheap. But for x-times the price.
If people knew beforehand what kind of "quality" they would be getting, I bet quite a few would reconsider buying, especially at the price level LEGO is asking these days.
Only the best is good enough? That's long gone.
@elangab: I always enjoyed underwater sets (I wish I'd been able to get more Divers and Aquazone sets, especially Aquazone), but I'll admit that they can look unnatural just sitting there, especially sets that include a boat and a sub, such as 6441, the only Divers set I own. Aren't those vehicles supposed to be at different levels? That said, I like your suggestion about the butterfly.
I wish LEGO would just commit to giving the Avatar characters guns. Overwatch characters had them, and LEGO doesn’t seem to mind giving Jake a vest with extra magazines; it just looks odd for him to have a crossbow. LEGO’s weird standard’s definitely contributed to me not getting the exo-suit set (plus, there are Ninjago sets with belt fed weapons!). I just think it’s quite silly, I mean, even Star Wars guns are just modified WW2 guns, and it’s not like the Sterling SMG (E-11) looks any less “scary” than a modern assault rifle.
@KingTyrannos said:
"I wish LEGO would just commit to giving the Avatar characters guns. Overwatch characters had them, and LEGO doesn’t seem to mind giving Jake a vest with extra magazines; it just looks odd for him to have a crossbow. LEGO’s weird standard’s definitely contributed to me not getting the exo-suit set (plus, there are Ninjago sets with belt fed weapons!). I just think it’s quite silly, I mean, even Star Wars guns are just modified WW2 guns, and it’s not like the Sterling SMG (E-11) looks any less “scary” than a modern assault rifle. "
To be fair guns aren’t really used in the Omatikaya village until the climax of Way of Water, I do remember Jake using one while riding a Skimwing in the final battle, though, so I can see your point. It probably seems odd to lack guns in the sets for a war film, I know, but maybe this is their way of distancing the theme from that aspect of Avatar. As a side note, I do think an E-11 is less intimidating than a modern assault rifle— but overall, yes, I would’ve loved to see some strap in these sets.
I REALLY like these kind of beasts, molded head + brickbuild body is a great combo.
I dont mint segmentation because here its done well.
Holy moly, Avatar 2 has arrived!
Yesterday was my youngest's birthday and he got no less than 3 sets of this wave, including the skimwing. So this review comes exactly on time to compare to our own experiences!
Thanks for the great review capn!
This makes me want a LEGO Mosasaurus, but I know the Mosa would eat these up.
@Lordmoral said:
"This makes me want a LEGO Mosasaurus, but I know the Mosa would eat these up."
The real mosasaurus was much smaller, compared to the super oversized one in JW movies.
But yeah, if LEGO would make a Mosasaurus under the JW theme, it'd probably be at least as big as 75579 : Payakan the Tulkun & Crabsuit
6721 from 2001 was a good Mosasaurus in my opinion. It's easy to find used on the aftermarket, but a bit pricy in "new" condition...
I tried something new while building this set.
I discarded the instructions, and built the entire thing using only pictures from the box!
LEGO has been getting a little stale for me lately, so this put more fun it it again. I highly recommend it with smaller, straightforward sets like this one.
Actually, I don't mind the imperfect color matching. Plenty of animals have shaded transitions between one color and another; this one seems particularly natural. And I'd rather have the flexibility than a perfect, rigid curve for the back. I picked this set out of the wave mainly for the wings; glad to see the rest of the set is equally attractive!
I like the minifigures but have no interest in Pandora's wildlife. Even so, I might pick this set up for the useful pieces.
