Review: 75361 Spider Tank
Star Wars includes an extraordinary selection of iconic vehicles, providing regular inspiration for LEGO. However, lesser-known designs are often interesting as well. They include the mysterious Spider Tank, discovered beneath the devastated surface of Mandalore.
75361 Spider Tank undoubtedly appears unique among LEGO Star Wars sets and potentially appealing, although I do find the choice peculiar, given how little is known about this vehicle. In addition, the price of £46.99, $49.99 or €52.99 is expensive for such an enigmatic subject, although the new Bo-Katan minifigure is enticing.
75361 Spider Tank, 526 pieces.
£46.99 / $49.99 / €52.99 | 8.9p, 9.5c, 10.1c per piece.
While impressive in some respects, 75361 Spider Tank involves too many compromises
  • Fairly accurate
  • Unusual subject
  • Outstanding minifigures
  • Missing important features
  • Lacks a proper pilot
  • Very expensive
The Mandalorian has now appeared in thirteen sets since his eponymous series was launched in 2019 and this version returns from 75348 Mandalorian Fang Fighter vs. TIE Interceptor. The updated helmet design looks excellent, featuring a decorated ridge across the top and a more accurately proportioned visor than the prior minifigure.
However, the torso and legs remain unchanged. The metallic silver armour continues to look splendid and I like the reddish brown straps on Din Djarin's chest, as well as his printed arms. Bo-Katan Kryze is equally detailed, or perhaps even more so! Naturally, there are similarities between this minifigure and her appearance in 75316 Mandalorian Starfighter, but no parts are shared.
The helmet, for instance, is now medium azure rather than blue and the decorative eye insignia above the visor is paler, which corresponds with Bo-Katan's live action portrayal. Otherwise, the metallic silver armour and leather pouches are similar to other Mandalorian minifigures, so they look brilliant. Moreover, the Nite Owl symbols adorning the shoulders are accurate to the series.
Both minifigures include heads beneath their helmets, but only Bo-Katan comes with her hair element, unfortunately. This piece is new and looks fantastic, in combination with the printed headband underneath. The two Mandalorians are also equipped with jetpacks and Bo-Katan wields her twin WESTAR-35 blaster pistols, while Din Djarin carries a pistol and the Darksaber.
Grogu completes the trio. This tiny figure was introduced in 2020 and looks adorable, as usual. The large eyes are nicely highlighted in black, with white dots in each, while the moulded detail is impressive too, considering the tiny size. Only the centre of Grogu's robe is decorated, which could be better, but reflects the limited area accessible to print between the arms.
Reference
Source - starwars.com
Din and Grogu encounter the Spider Tank while searching for the Mines of Mandalore. Almost nothing is known about this vehicle and the dark underground setting never provides a proper view of its design. Nevertheless, this mechanical beast captures the menacing appearance of the onscreen vehicle, which is unlike anything else in Star Wars.
I presume the designers had access to concept artwork shown at the end of episode eighteen when developing this model, as the head has received particular attention. There should be an additional trans-red light on the front, but the angled position, circular hatch on top and fang-like structures underneath each correspond with the source material.
The hatch does not actually open though and the head is fixed in place, but the grasping claws on either side are articulated. They can grip a minifigure easily and the ball joints alone provide ample motion, which is fortunate because the arms can swing just a short distance from side to side. Also, the arms decidedly lack texture, represented by the now-common limb element.
Several bulbous sensors cover the exterior, reminiscent of those on Imperial Probe Droids and each tipped with trans-black 1x1 round tiles. The round shape also resembles probe droids, so maybe the Spider Tank was constructed using Imperial equipment abandoned on Mandalore. A few light bluish grey pieces provide detail across the top, forming another hatch.
This hatch is functional, although not necessarily in the manner expected. Raising the central section reveals two stud shooters, which are oddly situated, but are valuable for play. Smaller hatches can then open on either side of these launchers, providing access to seat a minifigure inside the tank.
Frustratingly, the bizarre cyborg which pilots the tank onscreen is not included, likely because LEGO was not informed of their existence. Perhaps this also explains the unusual interior, as there is plenty of space for a minifigure, but no controls. The cockpit is also very deep, which leads me to wonder whether LEGO designed this area to accommodate a bigger character, if needed.
The Spider Tank ensnares Din Djarin in a cage on its underside, which is sadly absent from this model. Again, I imagine this relates to the designers' limited information about the tank, as that would have been a superb feature. There is potential for modification though because the legs are simply attached using Technic axles, so there is room for a cage between them.
Each leg can move back and forth, but they lack otherwise lack standard joints. Instead, the legs bump against rubber Technic beams when raised, thus adapting to anything underneath, such as unfortunate minifigures! Conventional ball joints or click hinges would probably have been superior for display, but I appreciate the unusual nature of this design.
75361 Spider Tank is an unusual subject for LEGO Star Wars and I welcome the change, but there are problems here. The monstrous appearance of the tank is striking and I am generally satisfied with the articulation, which is essential for a model with this many limbs. However, the designers clearly had limited information about the tank, inevitably detracting from its quality.
The omission of the cyborg pilot and the cage on the underside are disappointing. These flaws were doubtless outside LEGO's control, but the model feels incomplete without them. Also, the price of £46.99, $49.99 or €52.99 obviously does not account for compromises and feels very expensive to me. Given that price, desirable minifigures are not enough to counterbalance the issues.
45 comments on this article
Spider tank, spider tank, friendly neighbourhood, spider tank…
Sounds like Peter Parkers go to vehicle when he needs some heavy firepower
I've never seen this set in my LEGO store or Target and it's not listed as Retail-Limited. Am I the only one not seeing this?
I dislike the use of the limb element for the claw arms. I understand its use in legs that are weight bearing, but I see no reason those little arms couldn't use some sort of articulated joint there instead.
@yellowcastle said:
"I've never seen this set in my LEGO store or Target and it's not listed as Retail-Limited. Am I the only one not seeing this?"
its not out until august
Random and probably obvious prediction: Ten (10) years from now, that Darksaber blade will have appeared in a number of non-SW sets, with the majority of those sets using it for propeller blades.
Star Wars really needs to do better about informing LEGO, in my opinion. The cyborg character isn’t particularly plot significant, nor is it a twist character or cameo, I mean, it’s not like it’s General Grievous returned from the dead or something. There’s no reason as to why LEGO could not be informed about the character, and honestly I just find it disappointing, and I think it could definitely hurt sales.
I know when I was young, a particularly cool character, usually an alien or the like that looked unique, was always a big draw to me when deciding what sets I wanted (luckily, I feel as if I got good sets out of minifig-hunting as well, and it was always exciting to find out the set was incredibly solid when I only asked my parents for it because of a specific character!). Personally, I feel as if the set is at a disadvantage, it’s got limited screen time and it loses the one fight it’s in (kids don’t like that very much), and Bo and Din are in other sets, with Din being a very saturated character at this point. For double the price, you can get two medium-large ships, with the same characters. The cyborg is what’s unique about this vehicle, but he’s not even here, there isn’t even a print of his eye, because LEGO presumably thought the tank was a droid.
I’m interested in the set still, at a discount, because I like the tank design, but I’m sure many will pick it up for the saber and characters, as it’s half as cheap as the TIE/in and Fang Fighter. Sometimes I feel bad because I feel as if LEGO has become too collector focused, and it’s caused the sets to be less substantial for kids, as collectors are honestly even easier to pander to.
This is a bit of a weird set. It got announced quite early with a long time until release, and I think that is clearly an issue as the review does point out. This has happened before (it happens with action figures too, but with LEGO it's a little less excusable), and I feel like it's the sort of set which would have made a great playset for £50 if it had a small diorama like the cage Din is held in, and perhaps a way to hold Din under the Spider Tank, but given the limited information we assume the designer had, we have an expensive set with only minor correlation to the events of the episode.
Personally I feel like there are other scenes and events in the show which would make better sets than this, and any merits this set may have had when it was announced seem to have been lost given the long time between announcement and release.
A weird set indeed. I'm not sure I really like it and there is some expensive desirable stuff coming, so maybe on a deep discount in the darker days of winter...
@KingTyrannos said:
"There’s no reason as to why LEGO could not be informed about the character, and honestly I just find it disappointing, and I think it could definitely hurt sales."
Yep, everybody loses in this scenario. I get that Disney have bigger concerns than Lego sets when it comes to IP secrecy, but all parties would benefit from this set having a unique cyborg piloting this unique vehicle. It's still a good set, but could have been a great one.
Having not watched any of the Star Wars TV shows and therefore knowing nothing about the subject matter, I do think this is one of the coolest-looking Star Wars sets in recent years. Feels like something out of a sci-fi anime or video game.
Needs a Nick Cage Superman.
This is from a very poor episode of a very poor season and it's not even that accurate so the only thing here worthwhile to get is the Bo-Katan figure. Guess I'll bricklink her.
Still looking forward to this set. Getting a good Bo alongside a Grogu, an upgraded Din, and a Darksaber all in a mid-range set is quite desirable and the scene represented in this set is an iconic one, so I'm looking forward to the set, but the execution seems questionable. There's a distinct rust-orange lighting in the scene that isn't reflected here (even if the greys are faithful to the concept art and likely accurate to the robot's appearance in neutral lighting, giving it rusty colors would be more visually striking), the lack of representative play features (cage to hold Din, pilot alien), and strange (but adequate) articulation. Ideally this would be a $30 set but I don't think this is expensive beyond reason.
I thought it was already out, weird. It makes me wonder why the set was anounced already whilst the Mandalorian S3 episodes were still coming out (I believe it was right after this actually debuted in the show itself). Why do that and then wait nearly half a year to actually release it?
And even based on old concept art by the looks of it btw. If you're going to be late, why be early with the reveal? Is the hype built that way worth it that much?
And yeah, I kind of like the set for the tank itself, but certainly not at that price. It doesn't help that it's the usual near-monochrome of Star Wars sets. It makes it more 'sci-fi' looking, sure. But I wonder what it could have looked like in shades of brown. Probably far more memorable (as a set).
Oh, and that Bo-Katan hairpiece is a nice surprise.
The execution of mechs by Lego itself has been lackluster for a decade now. Why do they constantly feel the need to limit articulation in such drastic ways? With a simple set like the 2007 AT-ST you could just remove 4 plates and have functioning and movie accurate joints to actually put its legs in a walking pose. Since then every AT-ST had absolutely static Technic beam constructions that if posed differently make the model fall over immediately. This one is the exact same but worse because the smaller size would have made it easy to include functioning joints and the excessive price for the small size of the model makes their absence insulting.
@KingTyrannos said:
" Personally, I feel as if the set is at a disadvantage, it’s got limited screen time and it loses the one fight it’s in (kids don’t like that very much)..." Depends on the kid. I haven't seen Season three, but I imagine it loses the fight to the heroes, which some kids would like.
If this is called very expensive, then what was 75203 : Hoth Medical Chamber called, at €50 in 2018.
I know it was a case of Regional pricing, but nowadays it seems to happen the other way around : 60342: The Shark Attack Stunt Challenge being €20 or $35 US.
Actually, this reminds me of 75013 Umbaran Mobile Heavy Cannon, which was the same price a decade ago. The HMC had four minifigs to this set's two plus Grogu, but this set has 33 more pieces, and they're a similar size. To me the price is reasonable.
Give Lego one year until Bo-Katan gets released in a cheaper, cooler set, therefore losing the reason to buy this expensive flawed set.
Thanks all for clarifying this set was still a month away. As the review made no mention of a future release date, a couple hundred people already show they own it, and the set was first profiled months ago, I figured I was just missing it in stores. :o)
@ResIpsaLoquitur said:
"Needs a Nick Cage Superman."
I'm not a superhero fanboy and even less so DC, but I thought The Flash was simply fantastic.
So which one of these minifigs is Superman?
The hole inside the spider looks to be big enough for an Astromech? Maybe at some point in the concepts they planned to have the spider capture R5-D4 and Din/Bo go to save it? I agree with other comments and believe this is a strange choice of a set.
I really like it. I think it’s perfect for anyone wanting to make spider mechs for a cyberpunk style city.
@Jackthenipper said:
"Spider tank, spider tank, friendly neighbourhood, spider tank…
Can he swing from a thread? No he can't. He's a tank. Watch out! Here comes the Spider-Tank!
Honestly, this just looks like the Spider Tank from Ghost in the Shell to me ??
I reckon this would be a great set to modify, seems like many of the missing features could be added in with some reverse engineering.
If this is the only set offering the updated Bo-Katan fig I’ll buy it eventually when 20% off.
It’s only early here but I immediately thought this would make a good Star Wars set. Then realised it IS a Star Wars set. The ‘Spider Tank’ bit threw me off I think. So I think it would make a good Marvel set.
I think the pricing is fair based on what you get. However, I feel like this could have been pulled off at a much smaller scale and therefore a lower price. Seeing how they don’t include the pilot of this vehicle, there was really no need to allow it to hold a minifigure.
Anyways, this is a very different type of set than your typical Star Wars set and that is a good thing. Yet I don’t really think it’s necessary as it appears in a single episode and there are many far more interesting subjects on Mandalore that could have become sets. If I can get this cheap I might, but most likely I won’t be buying this one.
Great set.
I just like the design of this Lego set, designers did a great job. Shame the price is so bad because it looks like a solid partpack...
@ComfySofa said:
Yep, everybody loses in this scenario. I get that Disney have bigger concerns than Lego sets when it comes to IP secrecy, but all parties would benefit from this set having a unique cyborg piloting this unique vehicle. It's still a good set, but could have been a great one."
I definitely agree with you guys, and CapnRex. But, you can't be too hard on either of them (Lego or Disney) without having more indepth knowledge about the design and production process.
Studios and toy designs are under pressure to make cool stuff within budget and on schedule. Decisions about plot and design can easily result in the toy designs being inaccurate. It's definitely not in either company's best interest. Thus, I can excuse ths sort of thing a lot easier than I can bad minifig prnting, for example. Moreover, the inherent nature of Lego allows us to modify the design.
Hopefully, the companies will minimize inaccuracies. Nevertheless, I'm happy to have this set because it is so different... but, att a 20-50% discount. The set is cool, but the figs are largely redundant.
@560heliport said:
"Actually, this reminds me of 75013 Umbaran Mobile Heavy Cannon, which was the same price a decade ago. The HMC had four minifigs to this set's two plus Grogu, but this set has 33 more pieces, and they're a similar size. To me the price is reasonable."
Loved that set. It allowed me to collect the yellow troopers of the Iron Battalion or Star Corps. https://starwars.fandom.com/wiki/13th_Battalion
https://starwars.fandom.com/wiki/327th_Star_Corps
Plus, we recieved 2 of the only non-droid CIS troopers- other than 75041
Man, I hope this one gets released outside of the Lego store too. At a 30% discount this is a decent set!
It releases 1st August
@Zink said:
"I will modify this to be more like the tank from Ghost in the Shell"
The tan hexapod tank from the original movie, or the Tachikoma from the TV series? If the latter, I suggest adding goofy eyes - the Tachikoma didn't have them but they would absolutely be in keeping with the Tachikomas' personalities.
Either way, it'll take a lot of work. GitS think tanks all have both a thorax and abdomen, with the legs attached to the thorax, where this just has a single disc-shaped segment.
Great review. Please, the background better in another colour when the set is mostly grey. :-)
Nice review CapnRex101! I was waiting for your review pictures of the actual set. Because in the Hoth Bricks review Mando’s flame thrower print (brown box near the hand) is new and differs from the previous version (brown box near the elbow). Your version on the other hand is the same as the previous version….
That Bo Katan minifigure-
Absolute.
Perfection.
I like this set, but I do miss the spider droid, I want a discount though.
Another set to skip.
