Review: 40820 Up-Scaled Santa Minifigure
Posted by Huw,The series of upscaled minifigures debuted in 2021 with 76393 Harry Potter & Hermione Granger. A total of seven have been made to date, including the adorable 40767 Up-Scaled Baby Astronaut.
40820 Up-Scaled Santa Minifigure is the second retail one to be released this year, following the rather boring and uninspiring 40819 Up-Scaled Racing Driver Minifigure.
Given that Santa minifigures are perennially popular, I suspect that this one will be better received.
40820 Up-Scaled Santa Minifigure, 761 pieces.
£54.99 / $59.99 / €59.99 | 7.2p, 7.9c, 7.9c per piece.
A delightful addition to the series of six-scale minifigures
- A good likeness of the original minifigure
- Printing could be better
- Head can't be removed easily
The set contains two unique printed pieces for the front of the torso and face which approximately replicate the decoration on last year's updated Santa minifigure.
Unfortunately, the white print on the red panel is not as good as it should be: it could have done with another coat of paint.
The body and legs are built in much the same way as those in its predecessors, with hidden complexity inside the torso to provide sufficient friction on the axles used for mounting the arms, allowing them to be posed at any angle.
The head and hat are of course different, though, and both are incompatible with the other figures. The hat is held at an angle with the aid of bar and clip connections.
The figure stands at about 27cm tall and has full articulation of arms, legs, and wrists. Like the bearded minifigure it replicates, the head can't be rotated, and the beard is attached to the torso as well as the head which prevents the head from being easily removed and swapped with one from one of the other six-scale figures.
The bobble on the hat is very well modelled, making use of the myriad new curved wedge slopes that have debuted recently.
If you have any of the other figures, you'll know what to expect, and you won't be disappointed. It's a lovely model to display on its own, especially over the holiday season, or with its brethren.
The price, $54.99, £46.99, €54.99, is the same as the first single one in the series, 40649 Up-Scaled LEGO Minifigure, despite having almost 100 more pieces, so I have no reason to complain about that. It'll be available at LEGO.com from 1st October.
Which figure would you like to see upscaled next?
51 comments on this article
Ugh. Nearly 55 Euros for this minifigure, and the legs aren't even dual-moulded.
I look forward to getting this one — it will be a fine addition to my collection.
Speaking of Star Wars, I hope there will be some upscaled figures for that theme, like for Harry Potter.
Upscaled figures from most IPs would be nice as well… what if there was one of Indiana Jones, one of Frodo Baggins…?
Let's not forget about LEGO's own themes, e.g. a Classic Space astronaut, a Robin Hood figure, an example from the CMF series…
The sky is the limit!
An upscaled Johnny Thunder (with the proper hat!) would be awesome!
Great review! I think one of the Forestmen or Johnny Thunder would be terrific!
Edit: you got the suggestion in before I did it, @Murdoch17, when you said
“"An upscaled Johnny Thunder (with the proper hat!) would be awesome!"”
Overall a pretty good figure, but the more I see it, the less I like that printed piece. The white doesn't match the bricks at all, and the black belt just stops. I can't help but feel they could have gone for a brick built solution here which wouldn't have had such issues.
It's a shame they couldn't print the black belt on those red slopes.
Still need a GiAnt Man in this scale, because they still have never done it justice. If HP can get these figs, so can Marvel (and SW)
I might have to make my own version of the pre-articulation minifigure.
Never thought I’d see the words “head can’t be removed easily” used in a negative context.
You want to kill me with indecision? Tell me I can have that *or* an upscaled Classic Spaceman.
@PDelahanty said:"I might have to make my own version of the pre-articulation minifigure."
Honestly, they should have done that as the Lego House exclusive, and made Redbeard available at retail.
@Crux said:
"Ugh. Nearly 55 Euros for this minifigure, and the legs aren't even dual-moulded."
While this joke would've landed better if the minifigure this set replicates wouldn't actually have dual-moulded legs (which it clearly does), I do agree with the underlying sentiment that a lot of folks only seem to come here to complain that LEGO is expensive -- to the point where I'm thinking they might be better off pursuing a different hobby.
On topic: perhaps the best upscaled minifig yet, but I still don't really see the point of this beyond the gimmick that it is a large minifig. I wonder how many they can do before the gimmick wears off. But probably a lot.
If they make an upscaled Star Wars figure, it will be the same size, less pieces, and 179.99
Looks alright and I'm not sure if I'll be purchasing once it's on sale.
It would have been so cool if heads and legs could be swapped between the upscaled versions just like regular minifigs.
Regardless, I'm enjoying this series. I have yet to get one, but I'm excited to see which others are coming, and I'll pick one up at some point.
“Head can’t be removed easily” is an odd con. Was there a word limit to reach for the summary box?
@Arendi said:
"It would have been so cool if heads and legs could be swapped between the upscaled versions just like regular minifigs.
Regardless, I'm enjoying this series. I have yet to get one, but I'm excited to see which others are coming, and I'll pick one up at some point."
I don't have plans to get any new upscaled minifigures, but I did pick up the Harry & Hermione set a few years ago, basically because it was on sale at Target for $60, making it an amazingly cheap parts pack. I disassembled Hermione long ago, but still have Harry standing intact on the shelf, awaiting the time I figure out how to turn him into Barnabas Collins.
As I say every time there's a new one:
Batman, please and thank you.
As with Redbeard, I’m just disappointed there isn’t an actual minifig tucked away in the hat piloting their scaled-up duplicate to continue the joke that 40649 started
Looks like they involve dozens of molding steps.
Still wish they would make a stormtrooper like this!
Lego should fix his (white) printing problem before going to 3D printing… ??
IMO an 'okay article' about an 'okay set'. I don't think I'll buy one though, because I already have a couple of them (set 40649-1 being one of them) and will be using their parts to combine them into another upscaled figure (with some additional parts needed.) Plus, only the upper parts/thighs from this upscaled Santa figure -needed for my idea- aren't enough for me to spend EUR 55,- on it.
Therefore, because of my little plan, @Huw, I can not agree with your opinion of "the rather boring and uninspiring 40819-1 Up-Scaled Racing Driver Minifigure." Didn't you notice its red Classic Space helmet and its red hips? (Apart from that, being a petrol head and liking the LEGO sub-brand Octan, I think 40819-1 looks good on its own too.)
For now all I need are some upscaled monotone red legs, a pair of upscaled red hands and the parts to make a certain upscaled neck-/back gear in red. That would make my version of an upscaled 'Santa' figure!
I still dont understand why they decided to print that white part instead of building it and PRINT THE SIDES.
Money no object and with infinite space at my disposal, I’d get it happily, because I love these upscaled minifigs. The Christmas line-up this year has been full of great kits and I’m left with some very tough choices!
Indiana Jones please.
@Arendi said:
"It would have been so cool if heads and legs could be swapped between the upscaled versions just like regular minifigs. "
This can be done to a limited extent, as seen in 40649's review.
@FuddRuckus said:"As I say every time there's a new one:
@chrisaw said:"“Head can’t be removed easily” is an odd con. Was there a word limit to reach for the summary box?"
Besides the fact that the word you're looking for is "quota," not "limit," there are multiple up-scaled minifigs, so wanting to easily swap the parts between them is easily understandable, so considering it a con when you *can't* do that is also understandable.
Batman, please and thank you."
@PurpleDave, is that you?
@gunther_schnitzel said:"Indiana Jones please."
Or, y'know, Johnny Thunder.
I will get this. this will be part of my annual Christmas Decoration along with 40499-1 . I suppose it will be standing or sit somewhere around the house and put back in the box come the new year.
I am still waiting for the Spaceman version. When this happens, it will again raise the problem of having the Lego Space crest in different colours to make large-scale spacemen in as many different colour as possible (I'd be happy with white and red - the original two - I suppose many would prefer blue because of Benny). When they do make it, I just hope the helmet will be fixed from 40819 - that helmet is wrong.
I think we all know what figure we're waiting for them to upscale next... Space baby was close, they're just teasing us at this point!
@HOBBES said:
"I will get this. this will be part of my annual Christmas Decoration along with 40499-1 . I suppose it will be standing or sit somewhere around the house and put back in the box come the new year.
I am still waiting for the Spaceman version. When this happens, it will again raise the problem of having the Lego Space crest in different colours to make large-scale spacemen in as many different colour as possible (I'd be happy with white and red - the original two - I suppose many would prefer blue because of Benny). When they do make it, I just hope the helmet will be fixed from 40819 - that helmet is wrong."
If they do it in blue, it should include an alternate print to let it be Benny and include pieces to build a cracked version of the helmet. 41636 did that. (Well, technically, it did the reverse of that.)
I still find it odd how much everyone seemed to dislike the Octan racer figure, I guess because it didn't hit the nostalgia button? imo the racer seems like a more interesting set, but to each their own.
@essel said:
"Let's not forget about LEGO's own themes, e.g. a Classic Space astronaut, a Robin Hood figure, an example from the CMF series…"
Supposedly next year's addition will be a Spaceman, idk if rumours have stated any colours but I imagine it'll be Blue (though, we haven't see a modern blue Spaceman outside Benny... so maybe they'll be white).
An upscaled Caveman, Orc or Cyclops would be great because it could double as a giant at minifigure scale.
Wish I could find photos of the BA Christmas Party from 20 years ago when a couple of members built a 6x Santa as part of the Christmas competition. This looks like a fun display model and I’m glad to see the theme continuing!
@jsutton said:
"Wish I could find photos of the BA Christmas Party from 20 years ago when a couple of members built a 6x Santa as part of the Christmas competition. This looks like a fun display model and I’m glad to see the theme continuing!"
Were Faceman and Murdock at the BA party?
Were Faceman and Murdock at the BA party?"
I pitty the fool!
@Huw said:
"Unfortunately, the white print on the red panel is not as good as it should be: it could have done with another coat of paint. "
This has been a problem for years. Like the colour inconsistencies in the bricks, TLC can't be arsed to fix it. Why would they? The idiot fans keep buying the sets anyway. "If it sells it's good enough" is the company motto now.
I managed to find one, but you can barely see the two Santas - https://flic.kr/p/5S46Mb
Can’t believe it’s been that long since that photo was taken.
Love the upsized horse and rider. That would make a great official set!
We also sorely need a Giant-Man and a Galactus.
@WizardOfOss said:" @gunther_schnitzel said:" @jsutton said:"Wish I could find photos of the BA Christmas Party from 20 years ago when a couple of members built a 6x Santa as part of the Christmas competition. This looks like a fun display model and I’m glad to see the theme continuing!"
I pitty the fool!"
I love it when a plan comes together!"
Galactus.
"We also sorely need a Giant-Man and a Galactus."
@Vindicare said:
"Galactus. "
I third this. Galactus is the only upscaled Spaceman we _really_ need.
@Vindicare said:
"Galactus. "
I third this. Galactus is the only upscaled Spaceman we _really_ need."
No, no he's not.
@Vindicare said:
"Galactus. "
No, no he's not."
Eh, we already got Galactus.
Instant buy. This is a great and fun upscaled minifigure.
Looks really good. Just needs an up-scaled sleigh and reindeer!
@Vindicare said:
"Galactus. "
No, no he's not."
Eh, we already got Galactus."
Be honest with yourself, Dave. That is not the Galactus you want. Your Squirrelgirl would be embarassed to even be seen with the Galactus we got.
That's not Galactus, that anemic thing is barely fit to be the real Galactus' herald. Don't come to my house with that poxy little mid-transformation-Goliath-cosplaying-as-Galactus.
@Crux said:
@Vindicare said:
"Galactus. "
No, no he's not."
That's not Galactus, that anemic thing is barely fit to be the real Galactus' herald. Don't come to my house with that poxy little mid-transformation-Goliath-cosplaying-as-Galactus."
Iron Squirrel and Iron Tippy have been eating ice cream with him all summer. I did have to tweak the design so he could actually sit down (pity the poor souls standing under that skylight…), but I’m happy enough with the result, for now.
Johnny!
Johnny!
Johnny!
@essel said:
"I look forward to getting this one — it will be a fine addition to my collection.
The sky is the limit!"
I did hear a rumour that Dumbledore and Hagrid were to be the next HP up-scaled figs but this was quashed...
But, yes, anything is possible now, it seems. Would like it if they stuck to non-IP characters.
I feel like this series is just like the Houses of the World GWPs. Either you have them all or you don't. I had just the pirate after my visit to Billund earlier this year, but decided to skip the others and gift a friend as they don't really appeal that much to me.
I like these Up-Scaled Minifigures. I enjoy the build experience of them, I like the end result and they're not so expensive I feel bad about asking for them when Christmas or my birthday comes around.
I do wish they all had a little controller in the hats though - there could be a lot of fun in coming up with small variations in how they're steered or small items to show the things that occupy their thoughts... (eg:/ a small racing cockpit in the racing driver; some reins and presents in Santa...)
Definitely hoping for a Spaceman and a Knight and a Witch and maybe some Monsters...
@brigadeschick said:
"I do wish they all had a little controller in the hats though - there could be a lot of fun in coming up with small variations in how they're steered or small items to show the things that occupy their thoughts... (eg:/ a small racing cockpit in the racing driver; some reins and presents in Santa...)"
I don't think they all need the same thing, but I do like Easter eggs. Say what you will about 40819, but the engine in his head is pretty cool.
