Ideas Showcase - Thunderbirds Are Go
As a child, I grew up watching many of the hugely popular Supermarionation puppet shows produced by Gerry and Sylvia Anderson, particularly Stingray, Captain Scarlet and the Mysterons, and Joe 90.
My favourite show, by far, was Thunderbirds. I used to watch the Tracy brothers of International Rescue go and save the world, usually after successfully getting out of self-created difficulties.
Andrew Clark's Thunderbirds Are Go Ideas project is nearing the end of its available time. I have featured this project in a previous Ideas Showcase article and I would really like to see this project reach 10,000 Supporters.
Read on as I describe a recent update that Andrew has made to this project. You will also get a chance to vote on whether you prefer the new project update.
Thunderbird 2
The Thunderbirds Are Go Ideas Project is based on the recent animated TV series.
Thunderbird 2 is the large, green VTOL aircraft that is used in most of International Rescue's earth-based rescue missions.
Thunderbird 2 is one of the best known Thunderbird vehicles, and it is capable of transporting pods.
The pods are capable of carrying a selection of support craft used for different rescue missions, most notably:
  • Thunderbird 4, a small, yellow utility submersible for underwater rescue.
  • The Mole, a high-speed, manned 30-ton tunnelling machine.
  • Elevator Cars that are used at airports to enable stricken aircraft to land safely.
The pods add more scope for play features.
Andrew Clark comments, "When I started designing the model I had seen several episodes of Thunderbirds Are Go, and additionally, I gathered reference material."
"This project did teach me a lesson: never make assumptions. I added the Master Elevator Car assuming that it would be in the new series. I later learned it does not seem to show in the new series. So a life lesson learned, don't assume the new series has it."
In this version of Thunderbird 2, the four legs swing down raising the aircraft. This is so that the pods can open up revealing the support craft carried inside.
The project has five printed Mini Figure Trophies (or Nanofigs) as the five Tracy brothers.
The five Tracy brothers were named after astronauts from the NASA Mercury programme:
The first Mercury flight, Freedom 7, occurred 58 years ago on May 5, 1961.
The Mini Figure Trophies are small enough to fit into the cockpit of Thunderbird 2.
Andrew has responded to the feedback on the project's Comments Tab, "Many people felt the project was missing a detailed minifigure of a least one of the members of International Rescue."
"I recently updated the project to include a Minifigure, as while the micro figures give a good sense of scale, their size and lack of being poseable can be a deal breaker for fans, so now the main pilot of Thunderbird 2, Virgil, has been added as an update," he said.
Thunderbirds Are Go
Thunderbirds Are Go is a TV series produced by ITV Studios and Pukeko Pictures that first aired in 2015.
The series was produced using scale models, miniature effects and CGI.
Thunderbird 2 has a very angular look, particularly the square looking Super Charge Intake System and Primary Thruster Engines down each side of the fuselage.
Andrew Clark has re-created this modern looking Thunderbird 2 extremely well.
The original series of Thunderbirds
The original Thunderbirds was produced between 1964 and 1966 using a form of electronic marionette puppetry and was first seen in the United Kingdom on the ITV network in 1965.
Gerry Anderson and his model making team extensively used LEGO bricks in the models back in the 1960s. Take a look at these images and see whether you can find the LEGO bricks.
Andrew comments, "The original series Thunderbird 2 was more organic, and I was not sure, back then, if I could pull it off. So I decided to base this project on the new series where Thunderbird 2 is more angular in the central body section."
In a recent Update, Andrew has managed to effectively re-create the curved, organic look of the original Thunderbird design.
The updated design does have a few drawbacks: the legs clip-on rather than swing up and down. Andrew would have preferred to have telescopic legs but he could not find a good way to achieve that.
The pods lift up instead of slide down.
Poll: Which Thunderbird version do you prefer?
The modern version based on Thunderbirds Are Go from 2015
The updated version based on the original Thunderbirds of the 1960s
Which version do you prefer?
Andrew Clark
Andrew is the designer of two, very popular, LEGO Ideas sets that have gone into production:
Doctor Who and Companions that came out as 21304 Doctor Who in 2015, and
The Flintstones that is currently in stores as 21316 The Flintstones.
In this three-minute video, Andrew describes his Thunderbirds LEGO Ideas Set Proposal.
Let's get this project to 10K
This project has just over 7,500 Supporters with only three months to go until it expires.
Let's see if we can get this project all the way to 10K.
That's easily achievable with only 30 new Supporters per day.
You have been Fully Advised and Briefed, F-A-B.
40 comments on this article
Well, at least Thunderbirds are more recent than the Flintstones and there is a relatively current version on TV...
I'm not entirely sure I agree with the same people getting their designs made over and over, but I desperately want this to become a set. I hadn't seen the new original Thunderbird 2 model, it's fantastic.
I don't know, feels too niche to me. But I'm probably out of touch with what kids are into today...
@MisterBrickster I think it's heavily dependent on why those people's designs keep getting chosen. There are several MOC builders that consistently submit very good builds that don't even slightly conflict with the Ideas rules (licensing rules, specifically), and I feel like the fact they keep getting to the 10,000 vote mark is a sign of that quality. However, if people are just voting because they like someone, regardless of the build itself, I totally agree. But it's hard to deny that people like JK Brickworks, Andrew Clark, and robenanne regularly submit builds that are not just good ideas, but close to complete and needing few tweaks to actually move to production, which has to be a major plus when they are judging these sets.
That update to the 60s version looks epic. I'd buy that, day one. We just need two more Elevator Cars!
This looks really nice
The 1960's version will always have my preference, not just because of how the aircraft looks, but the characters/nanofigs as well, not to mention the added 'pod vehicles' such as the Elevator Car.
If the design sticks to that, it will definitely have my vote, otherwise: fantastic build and effort, but no thanks, personally. Good luck to Andrew Clark!
I dimly recall seeing this before and being slightly disappointed that it was based upon the modern version of the show, instead of the original that I watched (on repeat) in the early 90s.
I’m therefore delighted to see the updated 1960s styles, which I think can genuinely be considered design classics. Unfortunate that this version doesn’t have the same impressive functionality of the first model (difficult given all the compound slopes and curves I’d imagine), but if it were possible to add them in some future iteration (or maybe just fill the gap at the front of the pod), then this would win hands down.
Thank you for a great article. I totally hadn’t gotten the Mercury programme connection, despite recently watching The Right Stuff!
Already supported quite a while ago. This would be a day one purchase for me.
Finally an IP that seems to be a match made in heaven for LEGO, after all the obscure stuff of late - other than the Flintstones of course :-)
Supported this one ages ago. I have my wires a bit crossed because I love the 2015 Lego model but prefer the original 1960s series. The original series designs are still sleek, iconic, futuristic, and totally believable, while the modern series designs always struck me as chunky and a bit toy-like.
The boxy shape of the 2015 TB2 really lends itself to a build out of Lego, and the original submission is a stunning rendition. The 1960s update just doesn't look quite right to me, it's got all the sleek curves but the ship has been bulked up in the wrong places.
I would buy this set.the 1960's show was my favored show as a child.
This may be my favourite Ideas set ever if it gets produced. That classic 60’s TB2 is amazing. Lego could even hold a contest to design pod vehicles.
I always found the Starwars 7124 and 75091 Naboo Flash Speeders had a kind of Thunderbirds vibe... must be the color
I really would like to have this one. But it is another licensed product, so pricing will be a problem.
Lego could add 1 pod with the set and sell loose pods with other support vehicles.
And of course the other machines Like TB1, TB3 and 5 should be sets as well.
Yay... I actually wrote to lego years ago at the Leicester HQ asking if they'd ever consider producing Thunderbirds, captain scarlet, stingray or even fireball XL5 Sets they did, nt give me a definitive answer but sent me a minifig keyring thanking me for my interest,
So i hope they make this, and maybe Fab 1..
It's almost as if they re-designed it for the 2015 show so that it was easier to build in LEGO!
Definitely want the 60s version of TB 2 but could we please have Minifig versions of Scott Virgil Gordon and Brains as well as the nanofigs? That would definitely up the desirability of this set.
I could then build Mocs of Fireflash, Sunprobe or Sidewinder as “rescue missions” :-)
I like the set, but I've no interest in the IP. Unfortunately the Ideas platform is much like the modern day movie industry heavily reliant on IP, franchises, remakes with very little original content.
Hope they do 60s versions of the figures alongside the ship. The new design has far too much going on, can't beat the classics. I feel like this would have been a good full Lego theme for the 90s or early 2000s, albeit at the cost of some curved detail.
I've never seen the show (old or new) but as a fan of all things Lego space related I think these are terrific! Love the creativity and look of the designs. Great use of the micro-figures too. I would definitely pick up this set in a heartbeat! Now I'm curious to check out the new show!
only one thing to say - F.A.B.
absolutely love this model/set. Voted for it some time back so happy to see it getting another push hopefully to 10,000.
Along with Wall-E this is my favourite Ideas set
The build seems to be outstanding, but the theme does not interest me the slightest. And that it uses nanofigs makes it a nogo for me.
Thunderbirds was among my favourite television series as a child and I enjoyed playing with the toys during the late 1990s and early 2000s so this project would be fantastic! I think both models look excellent, although I voted for the original craft as I have a stronger connection with that version of Thunderbird 2.
However, I am not sure how prevalent Thunderbirds is outside the UK. It has certainly been shown elsewhere but it is not necessarily comparable to a television series like Doctor Who which is popular around the world.
Best of luck to Andrew!
I've actually never heard of Thunderbirds Are Go. This looks very cool and I would absolutely support this set idea. As I mentioned, I don't get any references about this model or the series, but I would really like own one.
As for the version, I prefer the modern one, as I think the functions on that one are nicer and I'd like the overall look more. But I don't feel like my opinion is of any value here, obviously.
yeee, i was supporter 7780, really hoping this will be a set!
I've heard of it but never watched the show, unfortunately. However, I prefer the version from the modern show because I like how all the legs, pods, ramps, and such work without detaching from the main model. I'd buy the modern version, but I'm not so sure about the updated one.
Absolutely, one hundred percent the original 1965 version.
If you've never seen the original Thunderbirds, go look up a few episodes. Now. 30 Minutes After Noon, Terror in New York City, Path of Destruction, Atlantic Inferno, Sun Probe, Attack of the Alligators, The Duchess Assignment, Ricochet, etc.
Do it, you need to see it.
Never watched it. Never heard of it. But the MOC looks cool. Depending on price I may consider getting it even though I have zero affinity for the source material.
Ode to the Scott Memorial, Edinburgh.
"When all is said and done.
The Scott Memorial looks a lot like Thunderbird Three.
Which is odd because Scott was the pilot
for Thunderbird One."
As a random younger person in this world, looking at this from a normal.. consumer perspective
I have no idea what this is. It's a cool model but I feel if *I* have no idea what Thunderbirds is, that speaks for it's success as a product. I don't think this would make a good LEGO set but as I said, it's really well made.
I don't like nanofigs. Would have been nicer if the Thunderbird 2 was an actual minifig scale playset with some minifigs but then the scale of the small vehicles wouldn't make any sense.
Nah it's a pass for me, thunderbirds aren't relevant to me anymore and also never have been.
Wasn't the Thunderbirds a British program? That probably explains why most of us younger American's are scratching our heads as to what is while the older British and other Europeans here seem to be jumping up and down in glee at the thought. Frankly I don't know much about the show other than a few clips and stills I have seen which made me always think those puppets looked a bit creepy... but that is a sweet looking Lego spaceship so I won't complain if its produced!
My dad and his brother grew up in the 1960s watching Supercar, Fireball XL5, Stingray, Thunderbirds, Captain Scarlet, Space 1999, and Joe 90, and as a result I grew up watching Stingray and Thunderbirds on VHS. I always wanted Thunderbirds Legos as a kid, so I supported this project a long time ago. If I could give it an extra vote I would!
I remember watching the 60's Thunder Birds in syndication here in NYC when I was a kid.
Haven't seen it in years(!!!) but I always fondly remember the tremendous models and sets. That always stuck with me.
This is some excellent renderings for the kit. I'd definitely be interested in picking this up.
Good luck to Andrew Clark! Hope this gets made.
I guess people who don't know what Thunderbirds is feel the way I did when everyone was losing their minds over Voltron :p
If this gets the votes I feel like it’ll actually get approved. Thunderbirds was supposedly in the pipeline for Dimensions before it got cancelled so ITV are obviously interested in working with LEGO.
"Thunderbirds Are Go".... Or NOT since LEGO seems to shun clever creative designs and settle for dross instead. I very doubt that this superb set will be seen on shelves, LEGO are that stupid!
@TabbyBoy, that's a very ignorant thing to say. There are many reasons ideas we think are very creative aren't made. A lot more than just creativity has to be considered for sets, one of the biggest probably being license agreements. I too think this is a well-made set and very creative, but there are many things that matter. Is there a market for it? Can they secure the rights to make it to begin with? Just because a set gets 10,000 votes doesn't mean it will sell well. Don't insult Lego just because they aren't making a set you want.
I like it, but I'd prefer something a bit bigger - deformed scale to at least be able to seat one minfigure pilot (although nowhere near full-scale). Though going by the insane prices LEGO is asking for Ideas and other specialist sets (Stranger Things for example) that would likely be a non-starter.
Next up the FAB1 with Lady Penelope and Parker minifigs??
