Review: 10366 Tropical Aquarium
The Icons theme encompasses all manner of subject matter nowadays, and LEGO seems willing to try just about anything that it thinks will appeal to adult builders and attract new customers.
The latest such set, adding to the ever-growing collection of real-life objects made from LEGO, is 10366 Tropical Aquarium. It's a huge and expensive model of a fish tank, something that has not been tackled at this size before, and at first glance it looks beautiful.
10366 Tropical Aquarium, 4,154 pieces.
£399.99 / $479.99 / €449.99 | 9.6p, 11.6c, 10.8c per piece.
An intriguing and attractive display model that could have broad appeal were it not for its price
  • Exceptional parts usage
  • Beautiful, colourful, detailed, and different
  • Fun mechanisms
  • Fish won't die
  • Frame arguably unnecessary
  • Exceedingly expensive
New pieces and recolours
There are dozens of recoloured pieces, which will be documented at New Elementary in due course. It also introduces a new fin element, which is used on the fish and some of the aquatic plants.
Your first impression when seeing the set is most likely that it'll be fun to build all the coral and sea life from the wonderful array of colours and parts, but before you can tackle that the base and backdrop need to be constructed, and doing so is lengthy and slightly tedious.
The base comprises a sturdy frame, 1 brick and two plates high – the same as the width of 2-wide tiles, of course, which are used to finish off the edges later.
It's 32 x 64 in size, with an additional row of black studs along the sides.
Eight 16x16 tan plates make up the bed of the aquarium, which are covered in mounds of 'sand', swirls in the sand, and turntable bases which are used to attach the cave and other structures at an angle.
With the bulk of the aquarium fixtures completed, attention turns to the backdrop, which comprises 20 8x16 medium azure baseplates mounted on a black-bordered frame.
The swirly water pattern is the same on the top eight plates and the pattern repeat looks a bit obvious before the tank is populated, particularly as it ends abruptly at the sides of each plate. The instructions suggest that coming up with a pattern that looked organic using just two different parts was a challenge for the designers. I think it would have looked better if the joints of all the tiles did not align with the joints between the plates.
The backdrop is attached to the base using two rows of studs along the bottom, and click-hinges for additional strength. It's also affixed to the back of the cave with Technic beams to doubly sure it's secure.
There are several mechanisms built into the model -- more of which later -- but the most interesting is that which causes one of the sea anemones to sway. It's built into a rock and operated using a crank on the side.
At the point the photo on the right below was taken, the majority of the tank's structure and decorations have been added, just the top of the cave needs to be added, which is done later on once some of the coral and creatures have been affixed.
I'm going to look at the individual plants and sea life in detail below, but here's the completed model before the front section of the frame has been added.
Overall I estimate that it took me about 12 hours to build it, over three days.
Coral, plants and invertebrates
It's not until you reach bag 25 (out of 42) that the real fun begins: populating the tank with plants, coral, invertebrates and fish.
Two branches of seaweed are the first to be added, made using dark green and transparent green Leaf 2X6X1s connected to a core of Technic axle connectors.
This 'tree coral' utilises nougat plant stem junction pieces and 1x1 round bricks.
The sea anemone attached to the mechanism in the rock uses various reddish orange curves, including the new long 'macaroni' pieces, with a Mini Hat, No. 8 on the ends.
The other anemone is constructed on hinged Technic bricks, then nestled inside two dark orange Shell 10X11X6 W/ Cross Hole pieces that form the lampshade of 21357 Disney Pixar Luxo Jr., as you will see in photos below. I think it looks wonderfully realistic.
The light yellow piece used for the specimen on the left below, which resembles sea fan coral, is a Ninjago energy element, originally used to attach claws to minifigures, e.g. this one.
The one on the right uses orange Min Hat no. 17, and reddish orange minifig-scale coral pieces.
The next four coral specimens all exhibit NPU (nice parts usage): constructed using a lot of relatively common elements that have been recoloured.
Chef's hats and pith helmets
Mop heads and broom heads:
Finally, two varieties of plant help fill the gaps on the aquarium floor and add more colour variety.
Fish and crab
Despite being two legs short of a full set of ten (a pair of pincers and 4 pairs of walking legs) the crab looks excellent. Iron Man's mask crops up frequently in botanical sets and here it has been recoloured and used for the shell.
The tank is home to just four fish: two angelfish, a rainbow fish, and a dark red 'striped brickfish', native only to the imaginations of LEGO designers, according to the instructions.
All of them look spectacular, the right-hand angelfish below particularly, with a very attractive colour gradient along its sides.
The new fin element is used for their tails, and also the dorsal and pelvic fins on some of them.
The tank is certainly life-sized (52 x 48 x 21 cm, 20" x 18" x 8") although I'd argue that some of the contents are larger than that. Nevertheless, it looks incredibly realistic, vibrant, colourful, and packed with authentic details, far more than I'll have a chance to mention in this review.
Four mechanisms are built into it which are operated using controls on the sides. Three on the right of the tank make the anemone sway, the brickfish 'swim' and the crab emerge from the cave, while one on the left opens and closes the lid of the treasure chest.
These photos illustrate some of the model's detail, beauty, and ingenuity.
There's no doubt that this is an exceptionally attractive and desirable display model, one that would brighten up any home or workplace.
It's bursting with detail and colour [1] and is a joy to behold. The only complaint about its design that one could reasonably make is that the black frame obfuscates parts of it when it's viewed at an angle. However, it does not take much effort to remove it if you'd prefer it to look more like a diorama than an aquarium.
One thing that has attracted considerable complaint is the price. The 4,154-piece set will cost £399.99 / $479.99 / €449.99 which, for a non-licensed set with no minifigures, seems extremely high. There are a lot of large pieces in it, but also thousands of small ones so 9.6p / 11.6c / 10.8c per piece does seem excessive. However, it is a large model and when the amount of 'stuff' it contains is assessed, it might not seem so bad.
If you have deep pockets and are looking for an absorbing and challenging building experience that results in a unique model that's both eye-catching and eye-candy, you will find it all in this set.
The fish don't need feeding and will still be alive when you come back from vacation: more good reasons to buy it!
It'll be available from the 13th of November at LEGO.com.
Minifig and goat for scale.
[1] I believe it was said at the recent Fan Media Days that it contains parts in 85% of the current colour palette. One that's missing, surprisingly, is vibrant coral.
123 comments on this article
The colours are nice, and may provide a cheaper opportunity for people who want a big fish tank. That being said...
Get ready for massive lego sets that are only 95% complete unless you get it day 1 to get the GWP, that's two sets now, this and the Death Slice, with the feeder/purifier thing and TIE fighter respectively
The price of this plus the DLC GWP that should have been included for no extra cost is not a good look for LEGO.
No prints, no figs, just plain bricks at over 10 cents/part? Complete insanity. Especially when you compare this other multi-color display-only sets like 10315 or 10359. This should be $350 at most. HARD PASS.
If they made the aquarium from finding NEMO that would be more interesting.
Evil OGEL hard at work eh?
Re: price — “It might not seem so bad”
Ok
Great review thanks; I agree with everything said - when I first saw this I thought that looks great and was already thinking about where it could live in our already crowded house, then I saw the price which stopped that worry! As a diorama it makes more sense - removing the unnecessary frame (or even making it a lighter colour such as nougat to mimic a light wood) would also reduce the amount of parts (and price) - colossal dust trap too!
Well done, but I just want the crab
Price/pieces is less and less a good measure. Lots of sets are filled with unnecessary 1x1 plates, sometimes disguised as " inside jokes" as in Pixar Lamp and mid scale falcon, which clearly could have been bricks. We should weight the sets, assuming this is a good way of assessing the price anyway...
I don't know if it's just the photos not doing it justice, but every time I look at this set I can't help but be surprised that the fish aren't more colorful. Or perhaps I should say, more vibrant. Particularly the top two. I think the dark red used is a bit of a mistake. They look fine in isolation, but as part of the diorama the fish just don't "pop" the way I would expect them too.
Feels like 200$ creator set with no 1in3
@KyloBen1012 said:
"The colours are nice, and may provide a cheaper opportunity for people who want a big fish tank. That being said...
Get ready for massive lego sets that are only 95% complete unless you get it day 1 to get the GWP, that's two sets now, this and the Death Slice, with the feeder/purifier thing and TIE fighter respectively"
Yes, that’s an unwelcome trend that leaves a sour taste in the mouth. Especially since these are big, expensive models; they aren’t exactly impulse purchases for the majority of people buying them.
Always appreciate the reviews here on Brickset but why no mention of the Feeder/filer-thing, a GWP DLC that makes the Death Slice's lack of including the 4+ TIE Fighter in the original set seem almost non-controversial?
Combined with the price, no prints nor minifigures etc. this set seems like one of the most extortionate releases ever from TLG, and that is saying something in October of 2025.
At least there are no stickers. Perhaps that added €50 to the price...
This is almost more expensive than the real thing. What the hell LEGO...
I'll wait until a Lego display box website starts selling the perspex plates to fill in the missing glass in the tank.
@MegaBlocks said:
"I'll wait until a Lego display box website starts selling the perspex plates to fill in the missing glass in the tank."
Yes that seems inevitable and will make a good addition.
@The_Cellarer said:
"Always appreciate the reviews here on Brickset but why no mention of the Feeder/filer-thing, a GWP DLC that makes the Death Slice's lack of including the 4+ TIE Fighter in the original set seem almost non-controversial?"
I don't really consider it an essential addition, unlike the TIE. Nice to have, but easily built from your own parts if you miss out on it.
The snail is my favorite bit of the whole thing.
According to newelementary there seem to be a LOT of parts recolours, which I wonder if that inflated the price? Or perhaps vice versa, in that they did lots of recolours to justify the price.
I'd love to know how they came to the decision of making it so large, as I can't help but feel that if it was half the size, and half the price it would have been a lot better received, as it is a great looking build and lots of fun parts usage (when you get to that stage of the build). Was a smaller version ever on the table or was it a conceptualised as a £400/$500 /€450 mega-set from the start I wonder?
By in Panama,
Love the look, but holy cats, that's expensive.
Also, I think the anemone should have a clown fish.
"There's no doubt that this is an exceptionally attractive and desirable display model, one that would brighten up any home or workplace."
I disagree... The more I see it, the more I don't like it. The colours are tacky (I particularly dislike the background and colour) and it does look a bit thrown together. The fish are mêh too.
A more natural environment with better fish and less colour would float my personal boat a lot more.
Lets say something nice about this....
It has no stickers.
I like the new bricks.
This saves me a lot of money.
The lack of mini figures doesn't put me off, the price and ugly black frame does.
I like that there are mechanisms to try and make it more realistic, that is not something I realised until I read the review.
The coral by themselves could be separate botanical sets, like 10309, I'd pick them up immediately.
After reading this review, I am more persuaded for this set, but I'll wait for a big discount. I still prefer it without the frame, unless someone produces "glass" at a good price. I have other sets on my list I want more, I'll wait until I can afford this, which might be some time.
Another set that is not well received because expensive.
And then it's 20% under MSRP everywhere two months after release.
It looks like a $300 to $350 set because that is what it will sell as.
Would buy this to make a Payakan / Avatar way of water diorama.
Besides being a very attractive looking and colorful set, it is also a nice parts pack (just not for the listed price). It also seems like a good "template" for creating your own aquarium or terrarium. I'll consider adding it to my collection when I see a decent discount for the set.
Thanks for the great review, as always (though you misspelled "anemone" several times).
Rivendell please.
It wouldn't be too bad if they got rid of the black glass-less frame, got rid of the water background, got rid of the crap fish that don't look like fish, got rid of the treasure chest and crab leaving just the underwater diorama at about half the price. As an underwater botanics set, it would be fine. But as a fishtank, it is crap.
For fishtanks of that size, the premium ones are frameless at least at the front corners so that the view is not obstructed by thick bars. And if they need a frame to hold the glass together, then premium manufacturers try to minimise the frame width. So LEGO seem to have copied the cheapest, low quality tanks with really thick frames just to show it is a framed tank.
I love the coral/anemone builds, great colors and techniques you would expect from a botanical. Fish builds I'm less interested in.
I predict this will reach $100+ clearance soon enough. Too big and expensive.
Imagine if they released the plants as separate sets to build your own Aquarium
Yes it would be difficult with ground and rockwork but it has a chance to sell better
The difficulty with this review for me, and forgive me Huw as this honestly is not a criticism of you at all, is that the biggest issue wit this set is the price point. Is it really worth that price or not. And it's hard to really judge that if the person hasn't paid for it. That's also not a criticism of how this process works with you getting sets to review. I have no issue with that.
It's just that the price point seems incredibly high for what this is. Which means that for the majority, I expect the rest of the review loses a bit of relevance. Really it's, is this set so good it justifies what A/B/C paid for it, and we can't really get that here.
@MeganL said:
"Love the look, but holy cats, that's expensive.
Also, I think the anemone should have a clown fish."
If you have 31122 "Fish Tank" already, you can use the clown fish there, either as a model to make your own, or to MOC it further to match the scale of the ones in this new tropical aquarium. Just a thought...
Like many have said here, I love the look, and my non-AFOL wife would actually love it too (she enjoys sea life, shells, sea turtles, etc., for decorative purposes), but that price is just way too high. I'll wait for the (hopefully) inevitable 40% discount, before getting it.
As someone who actually used to keep tropical fish, I was very interested… Until I saw the price.
@Klontjes said:
""There's no doubt that this is an exceptionally attractive and desirable display model, one that would brighten up any home or workplace."
A more natural environment with better fish and less colour would float my personal boat a lot more."
Absolutely agree.
To me it looks almost comically garish. No real life home aquarium I have ever seen seen looks even remotely like it.
And as for the price, that's beyond ridiculous imho.
I predict that this will turn up next year at the 30 to 40% discount mark like all the other undesirable sets of the recent sale at LEGO online.
It will soon be available at 30% discount at lego.com, just wait 6 months.
Stuck in the filter, sadly.
For my needs, the most interesting part I have seen on this review is the 2x4 transclear plate used to hold the models for the pictures - is this included in the set? - because this part has not been made in transclear for quite a while (in 1986 for 5540-1 ).
When the Display box with background picture come around, this will make sense (mostly to avoid the dust). But then you will have to remove all the framing and the background - which is an awful lot of parts that you are paying for and finally do not display (probably half the set). I also wonder if said display box will allow for the controls to be extended outside the box.
It is not for me but, as always, I wish this set good luck because (1) it brings new parts, (2) it brings new recolours and I'm all for that. And for those who don't mind the price, I'm sure it'll look fantastic in a display box with a background and no framing - and potentially lighting.
Back in my day, NPU meant "Novel Part Usage".
(shakes fist at cloud)
Horrible price, I love the look of this set, amazing techniques and so many colors, however, that price with the lack of an IP or any minifigures. Yeesh
Stuck in the filter, sadly."
I hate to have liked that*
*according to JANG's thoughts-on-video, being stuck in the filter is a deadly for fish
Great review and even though it's not a set most people will buy, it's nice to see how it works and goes together. Thank you brickset for showing these sets off
I'm not a fan of the fish or the frame (or the price), but the rest looks absolutely excellent!
Now I'm wondering if this set will hit general distribution, if it does, maybe we'll see this show up eventually for €200. If not, I suspect very few people will buy it directly from Lego at full price.
You guys need to buy these big sets yourselves and not get them sent gratis by Lego if you really want to review them properly. How much they cost is a big factor in whether a set is 'good' or not these days
I think that we can officially retire all the theories about licenses, Disney tax, new pieces, big bricks, stickers, minifigures, printed pieces, etc... everything we always say to justify LEGO as the premiest of premiums. Those things are factors, yes, but sometimes LEGO is overpriced just because LEGO thinks they can get away with it.
@DekoPuma said:
"I don't know if it's just the photos not doing it justice, but every time I look at this set I can't help but be surprised that the fish aren't more colorful. Or perhaps I should say, more vibrant. Particularly the top two. I think the dark red used is a bit of a mistake. They look fine in isolation, but as part of the diorama the fish just don't "pop" the way I would expect them too."
Here looks to me the photography, the lighting is washing out the tones.
@drewtstew said:
"You guys need to buy these big sets yourselves and not get them sent gratis by Lego if you really want to review them properly. How much they cost is a big factor in whether a set is 'good' or not these days "
Would I personally spend 400 quid on it? Definitely not.
But that does not make it a bad set. We should remember that there are people with larger disposable incomes than us, so to dismiss it solely due to its price in our review would be doing some of our readers a disservice.
The price is absolutely insane, and while the animals look great for the most part, the backdrop and frame do not. There's a version of this set in my head that skips those entirely and looks 10x better in a real fish tank. Not to mention all of the different technic functions not being linked together for easy motorization? Lot of missed opportunities. I hate being the target market for this and being not only priced out (by a lot) but under-delivered to.
I just cannot for the life of me understand a person who would spend $480 for this. More power to you if you have that kind of disposable income, I guess.
Not according to the Brickset audience, apparently. Back when we did that "best set of the past 5 years" competition, I listed affordability as one of my primary criteria, and a bunch of people said that wasn't a valid factor, preferring to defend the "bigger is better" mindset and thereby justifying LEGO's outrageous pricing of sets like this one. Also, if the Brickset reviewers had to buy all their review sets themselves, we would get far fewer reviews and none of them prior to release (as this one is). I'd certainly prefer them to pay more mind to the price in their reviews, but I think them receiving review copies from LEGO is better for us.
@ACubeInABox said:
"Those things are factors, yes, but sometimes LEGO is overpriced just because LEGO thinks they can get away with it."
That's exactly correct for every business, not just LEGO. Price a product according to what you think the market will bear, and change the price (i.e., discount) until demand meets supply. I have no idea why LEGO thinks people will spend $500 on a fake fishtank, but clearly they do.
" @Klontjes said:
"The more I see it, the more I don't like it. The colours are tacky (I particularly dislike the background and colour) and it does look a bit thrown together. The fish are mêh too.
Absolutely agree.
To me it looks almost comically garish. No real life home aquarium I have ever seen seen looks even remotely like it."
How many real-life tropical (keyword: tropical) aquariums have you actually seen? Seeing as you live in Germany, where everything is drab and grey and the use of color was outlawed around 1871. Tropical fish and coral are usually brightly colored, so these colors are perfectly realistic.
I will agree about the background color being garish, however. The idea there is clearly to brighten the overall model and make it pop on display, and reflect the typically brighter (shallow and sunlit) hue of tropical waters. It works about as well as it does in Friends sets (i.e., not that well). A more drab color, like dark blue (my personal preference), would darken the model, hiding many details in the shadows. A more realistic *fishtank* would be open on all 4 sides, of course, but that isn't realistic for a LEGO model that needs supports for the fish, etc.
All that aside, my only other big complaint about the model is that stupid "brick fish." Bricks don't float, bricks can't swim, and neither will that fish, because it doesn't have a dorsal fin - which is a necessary fish-feature to maintain balance, to my knowledge. I have no idea why the designers tried to make up their own fish instead of just modelling another real one.
Fantastic review, thanks! This set is neat to look at. I suppose it really is fun to build. But it is only a great sources for parts, that’s it. I am still laughing at the price of the thing.
@BLProductions: I may live in a country you would consider drab, but I for one am happy that I don't have to trade places!
Nuff said.
Fantastic build and review! This may not be for me, but it does make me want one thing even more than I did before: a Felucia diorama!
I love the colours. Very pretty, very fun.
I’m glad most of the fish are real fish - I’d been given the impression that they were all invented, which felt like missing the point, but one invented fish compared to mostly real ones is more of a cute easter egg. When I was quite small, my family kept fish, and I have fond enough memories of it that money and space no object the combination of charming wiggly fish with excellently NPU’d underwater botanicals would be a no brainer buy, but as ‘tis my Lego wishlist is already alarmingly long and I’ll content myself with the old Creator 3-in-1 fish tank.
I’m sure we’ll never know exactly how well it sells, short of a truly epic failure, but it would be interesting to know. Perhaps there is a hitherto largely untapped group of fish enthusiasts happy to throw money at the brick version, whether in addition to or as a replacement for the real thing (dusting aside, you never need to worry about regular upkeep tasks or these fish dying or having to get someone to look after them for holidays and such). I certainly have no objection to Lego exploring big kits outside of the IP space, so long as they keep doing small and medium ones as well. It’s more interesting to have a variety to look at whether I personally want to buy them or not.
I was not really interested at once, but this is really, really beautiful. A true and vibrant hommage to nature, as simple as it can look and yet intricate and amazing as it can be. Colors,shapes, this is so beautiful.
Could've been half the size and still effective. It's way too big and way too expensive.
reviews have completely lost connection with reality as of late
I really like the flora and fauna. I do NOT like the medium azure background. It fights against everything else, making it just a big mess of *colors* instead of particular *things*. A dark blue background would make the tank contents stand out more.
I hope they’ll do a Dogger Bank aquarium next year. But then bigger and with less color and even more expensive and as gwp a herring and two pebbles
Needs a blue tang, too.
Has anybody already pointed out it's expensive...?
Just checking.
Great review that gives me a lot of ideas for tweaking the model. Part of the problem with the fish not "popping" is that in a real fish tank the fish do a lot more movement than even the most motile of plants, which naturally draws the eye. I'd use less of the orange coral and the red-to-purple plants, perhaps using the parts to make more brightly-colored fish. More of the dark kelp-like seaweed ropes would also help the fish stand out from their environment. I don't mind the black frame all that much--it does a good job of defining the space--but I would like to remove as much of that backboard as possible, or make it transparent. Using something this expensive as the basis of a MOC seems rather extravagant, but I don't mind waiting for a discount. If one never comes, I'll live....
Once again, LEGO trying to milk adults of every last penny, combined with GWP dlc. Feels like it really doesn't matter theme licensed or not. The adult tax applies. I love star wars, but had i been able to go back in time, Ninjago would be best pick. Lot of cheap sets, and collector sets not crazy overpriced
@ACubeInABox said:
"I think that we can officially retire all the theories about licenses, Disney tax, new pieces, big bricks, stickers, minifigures, printed pieces, etc... everything we always say to justify LEGO as the premiest of premiums. Those things are factors, yes, but sometimes LEGO is overpriced just because LEGO thinks they can get away with it. "
It is the AFOL/adult tax. Bigger set gets more eyes, so they can charge bigger prices, and stagnate production lines. Ninjago has been able to get away with lower priced UCS sets thanks to not needing to sell to adults. But I imagine that may change soon.
Kids, fetch the old newspapers, the coloured card, the poster paints, the wretched pva and the scissors that barely cut. We’re gonna make an aquarium!
By in Argentina,
It would be nice to see it submerged in a real fish tank full of water.
Hahaha, no.
Absolutely agree.
I predict that this will turn up next year at the 30 to 40% discount mark like all the other undesirable sets of the recent sale at LEGO online. "
I don't know, it looks very similar to the plastic ornaments you can buy to put in an aquarium. I doubt many people, especially in Europe, have tropical marine tanks with live coral. But yucky neon coloured plastic ornaments, judging by the number stocked on fish store shelves, they must sell.
It looks a lot smaller than it is at first glance. Once you notice that the background is made of 20 8x16 plates, that gives a much better sense of scale. It must be massive when seen in person.
That being said, the price is a huge turn off. This does not feel like 2 modulars at all, as beautiful as it can be.
@zanthrax said:
"Another set that is not well received because expensive.
It looks like a $300 to $350 set because that is what it will sell as."
Not in the U.S.
I was curious and took another look at the poll for this set, Tropical Aquarium:
No, it's too expensive 45%
No, it doesn't interest me 20%
No, but I like it 14%
Maybe, I haven't made up my mind yet 5%
Yes, if it's discounted 5%
Yes, eventually 3%
No, it's too big 2%
Yes, as soon as it's released 2%
That's as of one minute ago. Fascinating to see that only roughly 5% of us might be getting this set at the suggested price.
I've long wondered if anyone at TLG takes note of these in-house AFOL polls?
I don't think it's a bad set purely based on its own merits. But not only is it massively overpriced for what you get (and that GWP that should have been included only adds insult to injury), but even if that was, say, €300, I still think it would be a though sell.
Yesterday I already mentioned I see this as a missed opportunity for a modular aquarium theme consisting of much smaller base sets and add ons. But if it had to be one set, I think it would have made more sense to make it a lot less deep, and a lot cheaper in the process. More like an art set.
And one more thing: I can't hep but feel that new fin piece looks very familiar, I just can't put the finger on it. Am I confusing it with a different Lego piece with similar characteristics, or have I seen it from some other brand?
EDIT: The more I think about it, the more I get the feeling that what it reminds me of is a Fischertechnik piece. Which is an entirely different construction system so it would by no means be an exact copy. Still can't think of the exact piece, it's driving me nuts....
Thanks for the review and your remarks regarding price and value @Huw. I'm more impressed than I initially was, the functions look decent and were unexpected. Overall though I stand by my comments on the prior article - the price is absurd. I don't know how many of these TLG expect to sell but I suspect this will flop. It's nice to look at, but doesn't have the pull that an established IP does and £400 is a lot of money. If I had that burning a hole in my wallet and had to buy lego with it, there are many obvious contenders that would come ahead of this, starting with Rivendell and Barad-dur.
Anyway. At least next year's Speed Champs are off to a flyer; I'm hoping that there will be some (any) Technic sets worth buying as lord knows this year's been a bust..
I like a lot about it. But like most folks here, I will not likely ever get the opportunity to own it as it is simply too expensive for what it is and what you get. Also, it feels they put all their efforts into everything but the fish.
This might have been a fun modular exercise where the primary set comes with just the basics and then LEGO sells different fish, coral, crabs, anemonies separately. This way you could always be adding to it and customizing it.
Additionally, it doesn't appear that LEGO put any thought into motorizing the functions which is a bummer.
P.S. I like the backdrop color and don't have a great issue with the frame.
There would be no reviews of this set if LEGO did not give it away for free. Strange choice by LEGO here, who is going to buy this?
@ramnicros said:
"It would be nice to see it submerged in a real fish tank full of water."
Someone on YouTube did submerge it in what looks like a private swimming or plunge pool. And it looks weirdly good underwater :~S
You know guys, if you cut down your grocery budget to 1 meal a day, max out your credit cards, and sell your kidneys in an alley, the price on this set isn't so bad.
@followsclosely said:
"There would be no reviews of this set if LEGO did not give it away for free. Strange choice by LEGO here, who is going to buy this?"
Yep. Ridiculous. Also consider that this joke losing money will raise prices on the future sets people actually want.
@WizardOfOss said:
"I don't think it's a bad set purely based on its own merits. But not only is it massively overpriced for what you get (and that GWP that should have been included only adds insult to injury), but even if that was, say, €300, I still think it would be a though sell.
EDIT: The more I think about it, the more I get the feeling that what it reminds me of is a Fischertechnik piece. Which is an entirely different construction system so it would by no means be an exact copy. Still can't think of the exact piece, it's driving me nuts...."
Oh man, having it be more shallow and flatter like the Gotham City set would've been so cool! Scale down the fish too so you could have many more types would be awesome! Sounds like a cool MOC idea.
@ScholtzTKO said:
Yep. Ridiculous. Also consider that this joke losing money will raise prices on the future sets people actually want."
This set, like the Death Star, probably doesn't need to make a profit. The attention it brings to LEGO will offset poor sales.
But that does not make it a bad set. We should remember that there are people with larger disposable incomes than us, so to dismiss it solely due to its price in our review would be doing some of our readers a disservice."
I agree with the rationale but I think it would be quite nice if the reviewer stated at the end of the review if they'd personally buy it at list price, just for another point for consideration. It would also be a real stamp of approval for the ones you would buy!
I could see this get a 25% discount ($360) which is more in line with a non-licensed set containing zero minifigures. Any reduction bigger than this would be an outstanding value. Will keep an eye out just in case.
@skypilot22 said:
"I just cannot for the life of me understand a person who would spend $480 for this. More power to you if you have that kind of disposable income, I guess. "
There's literally millions of afols globally that do have that disposable income. Lego is already premium luxury toy maker and will increase their prices again next year just to slow down global demand. They know you can afford it along with dozens of similar sets. if you could only have access to their real numbers you'd understand. expect $1,500-2,000 sets within few years and those will be sold out as well. people are hypocrites, that's the problem, Lego is smart
By in Croatia,
So true and sad. Lego is getting more and more greedy
@KyloBen1012 said:
"Get ready for massive lego sets that are only 95% complete unless you get it day 1 to get the GWP, that's two sets now, this and the Death Slice, with the feeder/purifier thing and TIE fighter respectively"
I think there's much more than the two you mention. Search the GWP tag here on Brickset and you'll see a bunch of them, here's a few from the last few years:
5009157
5009422
5009823
6535735
5008076
6373603
6322501
Sooooo,......
this is worth one-half of a Death Slice?!!
(StyleCounselor's head explodes in a thousand points of gleaming light).
Thanks, @Huw, for reminding me that Brickset is still cool: "Fish won't die."
Having just bought Ninjago Gardens with 150% more pieces (including some big ones) for 80% of the price does make me wonder what they're thinking. If it was priced similarly it would be £220 which would be far more palatable.
It amazes me that the review states that the price is high and "exceedingly expensive" and then people moan that the review is not overwhelmingly negative due to the price.
Are people expecting 1 star reviews purely because of the price?
The users of this website are supposed to be adults, yet they're acting like entitled children.
"Goldfish shoals, nibbling at my toes..."
No vibrant coral? I think LEGO did this to seem ironic and “edgy”. My favourite colour from the current pallet too . :( But I do find this set to be very attractive, just not day-one purchase attractive.
5009157
5009422
5009823
6535735
5008076
6373603
6322501"
I'd question the idea that any of those are "essential" elements that were fiendishly omitted from the set to force you to get the GWP. But then again, I also think that's a questionable complaint about the TIE to begin with.
5009157
5009422
5009823
6535735
5008076
6373603
6322501"
I'd question the idea that any of those are "essential" elements that were fiendishly omitted from the set to force you to get the GWP. But then again, I also think that's a questionable complaint about the TIE to begin with."
Stuff like the United Trinity are minifigures and not at the scale of the Old Trafford set, which actually includes the statue as part of the set, so definitely not a missing part of the set.
Whereas the TIE Fighter has all over its packaging that it is to be matched with the Death Star. Making it very clear that it is part of the larger set.
5009157
5009422
5009823
6535735
5008076
6373603
6322501"
It’s kind of fascinating because there were a couple of big sets this year that didn’t get specialised GWPs and there were people complaining in the comments about that, too. Lego really can’t win.
None of them have seemed particularly essential - the closest is, at least to me and off the top of my head, the Botanical Garden entrance gate just because it’s really cute and I like it a lot, but I’d be hard pressed to argue the set is actually incomplete without it.
Tank for the review.
I think it’s much better with the frame.
The display value seems a lot dependent on the lighting, surrounding, height, etc. See on the official images: lighting on the set but dark around (not easy to achieve).
I’m wondering what would be the effect of having background in the two sides (maybe bad unless we can only see it from the front).
If I was setting prices at Lego, I would make this set very expensive so we would make the most money out of STANs day 1.
And then after a few weeks, I would let the online store offer a nice discount, say 25%, so the set is sold ant its real price but everyone thinks they got a good discount.
Luckily I am not working for LEGO ^^
@Brickeric said:"Tank for the review."
That pun seems a bit fishy.
@Brickeric said: "The display value seems a lot dependent on the lighting, surrounding, height, etc. See on the official images: lighting on the set but dark around (not easy to achieve)"
I believe the display value of many sets could be enhanced with the right lighting, which is a bit frustrating given the lack of official lighting options and how many would greatly prefer that over third-party solutions (which often cost like 2/3 of the set itself) or screwing around with soldering etc. One of the worst offenders was that recent X-files Ideas contest winner (hinging too much on realistic daylight in the office and special light sources for the flashlights and the UFO beam to create the right eerie mood).
The artwork for the modulars also cheats quite a bit - they put the camera on a stand and first take a picture with just the ground floor, then a second picture with the second floor added, a third with the third floor and finally a fourth complete with the roof. Then they photoshop them all together, the sidewalk and the first floor from the first picture, second floor from the second picture and so on. That way each floor is shown with nothing above it and their interiors nicely light up, as opposed to the murky darkness you'd normally get when viewing the completed model.
5009157
5009422
5009823
6535735
5008076
6373603
6322501"
Whereas the TIE Fighter has all over its packaging that it is to be matched with the Death Star. Making it very clear that it is part of the larger set."
Seems to me that works the opposite way around: The Death Star looks complete by itself, but the TIE Fighter doesn’t make any sense at all without the Death Star.
The filter add-on GWP is pretty cool but yeah a bit of a kick in the teeth if you'd spend that much and not get it. This one is just a bit... too much.
Yet another giant dust collector that nobody asked for. Quantity over quality is TLG's answer to suck in new customers because long time AFOL's are starting to lose interest.
One thing that was again not mentioned in a review is the fact that this is yet another high priced 18+ set, where part of it was deliberately taken out to be offered as a 1st week GWP (similar to Shackleton's boat from the Endurance, TIE Fighter from the Death Slice, Market Van from the Italian Riviera, Taxi / Moving Van from the Modulars etc.).
This is a concerning trend that needs to stop asap. This FOMO tactic is anti-consumer and only drives more fans away from LEGO. A GWP should never complement a set, but be a nice bonus that customers can leave out freely. Or at least be able to buy with Insiders Points at a later time.
@MegaBlocks said:
"It amazes me that the review states that the price is high and "exceedingly expensive" and then people moan that the review is not overwhelmingly negative due to the price.
The users of this website are supposed to be adults, yet they're acting like entitled children."
Afols ARE entitled children. They don't hate Lego for putting high price, they hate Lego for not being able to afford EVERY single set they want. Lego is smart, using their addiction to milk them out of all of their money. Watch those 2025 profits soar to new heights once again. Lego managers would love to thank each and one of you for allowing them to drive the most expensive electric cars on the market lol, someone's got to pay for that as well you know
@R0Sch said:
"Yet another giant dust collector that nobody asked for. Quantity over quality is TLG's answer to suck in new customers because long time AFOL's are starting to lose interest.
This is a concerning trend that needs to stop asap. This FOMO tactic is anti-consumer and only drives more fans away from LEGO. A GWP should never complement a set, but be a nice bonus that customers can leave out freely. Or at least be able to buy with Insiders Points at a later time."
Interestingly, I would argue that to fulfill its premise, a GWP should be extremely tied to a set and appeal to the FOMO mentality to the highest possible degree. A GWP primary goal is to 'INDUCE' immediate buying. If nobody cares having the gift or not, it is not doing what it is supposed to do. Do I like that? not one bit but the primary goal of running a business is to maximize profits (emphasis on 'maximize' - not just making a decent profit but maximize profits).
In the case of the aquarium the GWP is completely irrelevant though. If I had been part of the development team on this, all functions would be linked together (but at different speeds - just different gear sizes really) and the GWP would have been a motor and battery box - which would be a great value GWP for this set - and would make the MRSP more palatable. That way, the functions would still be usable in a clear plastic display case. Anyhow, I'm not working there and judging by their latest profit numbers, they are doing just fine without me!
Afols ARE entitled children. They don't hate Lego for putting high price, they hate Lego for not being able to afford EVERY single set they want. Lego is smart, using their addiction to milk them out of all of their money. Watch those 2025 profits soar to new heights once again. Lego managers would love to thank each and one of you for allowing them to drive the most expensive electric cars on the market lol, someone's got to pay for that as well you know"
Overgeneralization makes for poor reasoning.
There is a correlation between vocal AFOLs and entitlement, such as on fan sites, but there are enough AFOLs who speak with their wallets first (and maybe comments second). With less people willing to sink massive amounts of money into LEGO upon each release, those who bother with the conversation are more likely to skew towards toxic positivity or entitled complaining. Personally, I have bought far less LEGO this year, and I don't often bother to vote on the "will you buy this set?" polls.
It would be nice to see more and more AFOLs putting their money where it matters and letting LEGO reconsider how they approach an unsustainable market, but we won't be hearing about that until the profits drop and the silent fans get their say.
It would be nice to see more and more AFOLs putting their money where it matters and letting LEGO reconsider how they approach an unsustainable market, but we won't be hearing about that until the profits drop and the silent fans get their say."
"It would be nice" ... and that's where it all ends right there. You leave out the most important thing that exist currently within afol community - Lego addiction. You just got to own that newest, shiniest set. And if you don't, you get mad, like a little child. Lego can afford and WILL produce more and more expensive sets because people simply buy them, it doesn't matter whether YOU no longer buy anything. You simply no longer matter, there are 10 others (globally) waiting in line to buy those sets instead of you. I'll ask you again when Lego releases their profits for full 2025
In the case of the aquarium the GWP is completely irrelevant though. If I had been part of the development team on this, all functions would be linked together (but at different speeds - just different gear sizes really) and the GWP would have been a motor and battery box - which would be a great value GWP for this set - and would make the MRSP more palatable. That way, the functions would still be usable in a clear plastic display case. Anyhow, I'm not working there and judging by their latest profit numbers, they are doing just fine without me!"
Well, I can only speak about my purchase habits, but I rarely buy sets at full price from Lego and even then it's only exclusives that don't make it to retail much cheaper AND if there is a "min. threshold" GWP as a bonus that is completely unrelated. I absolutely hate having to buy a new set on day one just because there is an artificially limited GWP tied to it. So I rather buy that GWP from secondary market for 20-30€ and wait 1-2 years until the large "exclusive" set is at a 25-30% discount IF I have the money and feel like it's worth to spend it. I am not falling for TLG's FOMO marketing schemes with cheaply made add-ons with artificial scarcity.
And to be honest, these high cadence GWP's every 2 weeks and monthly set releases just make them less interesting and desirable overall. Time, money and space are limited and the construction toy market is over-flooded.
" @AustinPowers said:
" @Brickeric said:"Tank for the review."
That pun seems a bit fishy."
"I'm gonna eat you little fishy..." "
Fish are friends, not food!"
And certainly avoid the green ones. They're not ripe yet.
And certainly avoid the green ones. They're not ripe yet."
1 fish, 2 fish,
Red fish, blue fish,
(Green fish was supposed to be be here but he was feeling a little green around the gills, so he stayed home today.)
""Goldfish shoals, nibbling at my toes..." "
Fun
Fun
Fun"
'Til her daddy takes the T-Bird away... Oh, that's not what you were referencing, was it?
I’m sorry. I have to call this out. Is this really novel part usage when the parts in question are in new, and never before produced colours?
I’m not sure. Is this Lego design just looking for a cheaper option than making a totally new part?
Thoughts?
Also this is far too expensive. I might as well get a real fish tank with 4 fish for this price.
They should have added an algae eater suspended right up against the middle of the invisible glass, ruining the pristine look, lol.
@Copper999 said:
"I’m sorry. I have to call this out. Is this really novel part usage when the parts in question are in new, and never before produced colours?"
Just because a set introduces a new color for a given piece doesn't mean its use of that piece can't be NPU.
"Is this Lego design just looking for a cheaper option than making a totally new part?"
Given that making new pieces rather than seeing what could be done with the existing parts palette is part of why Lego ended up doing so badly around the turn of the millennium that they were getting (and considering) buyout offers, it's not "choosing the cheaper option," it's "avoiding repeating past mistakes."
Fun
Fun
Fun"
In the sun, sun, sun...
What I find interesting is how many fish-related references there have been in Red Dwarf over the years.
This is one of those sets that I think looks great but also isn't for me personally.
Personally, when spending this kind of money, I'm looking for something that takes people's breath away, not something that just looks nice. 10307 and 10294 are more expensive than this, and the Eiffel Tower is quite dull, but the reactions I get from those two are easily worth the money. If I was going for sets that just look nice, I would much prefer to get both 10359 and 10315 for less than half the price of this set.
I was looking at the "2026 LEGO Batman Sets Revealed!" article and it occurs to me that between this and 76330, Lego seems to want to make display sets hard to dust all of a sudden.
@Escapade said:
"Having just bought Ninjago Gardens with 150% more pieces (including some big ones) for 80% of the price does make me wonder what they're thinking. If it was priced similarly it would be £220 which would be far more palatable."
Ninjago Gardens has 10,000 pieces?
It's $590 in Sweden.
Yes, you read that correctly.
Yeah. God forbid we do a ‘disservice’ to the already ultra privileged who are immune to all the BS of this world. Don’t want to hurt their widdle feelings. Your reviews should speak to regular people and what they go through. Rich people don’t need help or favors, like pandering.
@sotwuser said:
Ninjago Gardens has 10,000 pieces?"
150% piece count or 50% more
While I don’t necessarily hate this set, there are issues. I am an avid saltwater fish hobbyist as well as a Lego collector. You could get a huge freshwater or modest saltwater tank for the price of this set. I have a 100 Gallon artificial reef tank. In addition, none of these fish appear to be based on real tropical species, with the exception of the Purple and Yellow Royal Gramma. Disappointing.
The fish only 'pop' when fried
This set has highlighted to me that the question of value with LEGO sets has moved away from price per piece and relative value and into the realm of £400 / $480 is an awful lot of money to pay for any non-essential item, let alone a modestly sized decorative piece made of cheap ABS. That price is “fine”-ish in the context of LEGO (high but not exceptionally outrageous), yet zoom out and compare to the other things you could buy with that money, and it’s just not worth it. Even within LEGO, it’s only £30 cheaper than the still available UCS Sail Barge, and it’s £140 more expensive than this year’s UCS Slave I. Both of those sets, in spite of their flaws, offer clearly better value in my opinion, especially when you consider their size, presence on display, iconicity, minifigures and the fact they’re from a licensed theme so should naturally be relatively more expensive. Yet if you offered me both the Aquarium and the Slave I for £260 and I could only choose one, I’d pick the Slave I every time, and I don’t think that’s just because I prefer Star Wars, I think even at the same price it would be of better value.
So, Day One and the set is already on backorder. Guess the price didn’t scare everyone off, and I ordered it too. I’m just spending my kids inheritance. But I’m curious. The majority of comments say it’s overpriced. So, - how much would it cost to buy all 4154 pieces individually? I thought Lego sets were like cars, where the whole unit is considerably less than the sum of the parts?
