Review: 10323 PAC-MAN Arcade
LEGO has been tapping in to nostalgia for old video games recently and following two models of home games consoles it has turned its attention to arcade games, starting with perhaps the most famous and beloved of them all: Pac-Man.
10323 PAC-MAN Arcade builds a mini-replica of the arcade game cabinet and has an ingenuous mechanism inside to move the titular hero and the chasing antagonists around the maze.
10323 PAC-MAN Arcade, 2,651 pieces.
£229.99 / $269.99 / €269.99 | 8.7p, 10.2c, 10.2c per piece.
An eye-catching model of a classic arcade machine
  • Ingenious mechanism for moving Pac-Man and the ghosts
  • Instantly recognisable and reasonably accurate
  • Building the display is quite fiddly and tedious
  • Replica arcade machine can be bought for not much more
Parts and stickers
This premium priced set includes stickers which is disappointing. However, there are also numerous printed parts too.
Pac-Man and the ghosts are printed onto 1x1 round tiles and the there are three complete sets of them: two used on the model and a spare.
You will also be relieved to hear that the dozens of tiles used to create the blue borders of the video display are also printed, on five different sized blue tiles.
Finally, the Pac-Man sign at the top of the cabinet is also printed, on 8x6 slopes.
The set introduces just one new part design, a small chain link with a 318 bar on the side. These are used to attach the game characters to the mechanism.
In addition to the main model a couple of side-builds are included. Pac-Man being chased by Blinky and Clyde is a decent model in its own right and had it featured all four ghosts it would make a great standalone set. It's designed to sit securely on top of the cabinet for display.
There's a spring-loaded mechanism inside the base that is operated by pressing an axle in on the back. When you do so the tables are turned and Pac-Man chases the ghosts!
This delightful video arcade scene is built at the very end and can be stowed inside the body of the machine.
The mini Pac-Man cabinet accounts for most of the small stickers in the set.
The female game player has an exceptional torso, featuring Pinky the ghost on a white t-shirt under a Pac-Man-themed jacket. It's likely to be highly sought-after by those that do not buy the set.
The cabinet itself is 32 cm high, 25 cm wide and 17 cm deep and looks to be a reasonable recreation of the original machine, if not an exact replica.
There are very few exposed studs on the outside so from a distance it does not look like it's made from LEGO at all.
The back is fitted with a removable panel, held on by a ball joint at the top. It's taken off by pulling on the black ball joint at the top.
Doing so exposes the mechanism -- more of which later -- and the place where the vignette can be stored.
The video screen looks very realistic, thanks to the printed tiles that form the maze and the tan lightsabre blades used for the uneaten pellets. The mechanism underneath is not visible unless you look closely.
Operation
Sitting within the video screen are the chains, gears and wheels that make the characters move around the maze. It's all operated by turning the handle on the side of the cabinet, and a video is the best way to show the effect.
They do of course follow a set path, but they move very smoothly which is an impressive feat given the corners that are traversed. The manual states that the mechanism was tested for hours by robot (probably just a motor!) to ensure that they do so.
Unfortunately, they rotate as they move so do not remain upright, which is a shame but inevitable given the method use to move them.
Elsewhere on the model, the joystick can be moved realistically, thanks to the use of four Technic 1x2 rubber dampers, but it is not connected to anything, so doing so has no effect.
Pressing one of the buttons on the right illuminates the red coin slot underneath which on the real machine is much lower in the cabinet.
Finally, the high score at the top of the screen can be changed between four values by rotating a small gear, which can be seen in a photo below.
Parts are divided among bags numbered 1-14 and construction of the cabinet naturally begins at the bottom
Some nifty construction techniques have been used to join the two faces of the side walls together at the front while maintaining the yellow/black separation.
By far the most complex, time-consuming and, at times, tedious part of the build is the video screen and the mechanism within it that moves the characters. It's built upon two 19x11 'peg boards' which are appearing here in black for the first time.
Two chains to which the characters are attached are threaded around the maze, and an additional mechanism to move Clyde in the central holding pen is added after this photo was taken. The uneaten pellets are made by inserting a lightsabre blade into two black technic pins that are connected by a pin joiner -- 64 times!
Above the maze you can see the high score represented by a sticker, and current score on the left, which can be changed between four different values by rotating the gear wheel on the right.
The three movements are linked via gears and liftarms, and when inserted into the cabinet the black gear on the left -- a 16-tooth one appearing here in black for the first time -- will mesh with one connected to the handle on the side of the cabinet.
The thick subassembly is attached to the cabinet using bars and clips and once that's done it's just a case of building up the sides and top of the cabinet.
It's a great-looking mini-replica of a real-life object which those that spent hours playing the game in the arcades during the1980s will appreciate.
It's well-designed and building it is both enjoyable and in part intricate. The finished model looks great on display. The mechanisms are clever, but I suspect they'll prove to be fun for all of five minutes.
I guess the main issue with it is the price. 2,651 pieces for £229.99 / $269.99 / €269.99 is not unusually high for a set of this type, but as was pointed out in the comments to the reveal article, you can buy a fully-functioning playable version for not much more.
But, if you want a LEGO version and can justify spending out on one you will find much to like here.
It will be available from June 1st at LEGO.com.
78 comments on this article
Even as someone who spent a lot of time playing Pac-Man in its day, this set is not for me, but kudos to the designer for a thoughtful, faithful, and fun recreation.
Missed opportunity to include a functioning arcade game with lights sounds and movement!
What do you mean I’m expecting too much from d2c sets now...
Looks absolutely brilliant. It's overtaken the Land Rover on my £200+ wish list. Will probably wait for a higher threshold GWP though (maybe the rumoured 'Houses of the World 2' rerun in a few weeks).
Obviously not a set for everyone. Especially not the 'What's the point when you can get a real one cheaper' brigade. I guess they're not big fans of the 'Botanical Collection' either! But personally, I love the 'Wow, they've made THAT out of Lego' sets!
I still ask why didn't they print a .25 on that tile. Scrooge got his lucky dime.
I think the best thing is the side-build with minifigure. More of that please.
It is lovely... but, I'd rather spend the money on the actual game.
I saw this in Leicester Square today the movement was really impressive. Still don’t want it though.
Is it me or are these adult oriented sets tend to get larger and larger? How many of us have this kind of free space in our house? I barely made it alive after I got cought while sneaking 10497 into the house. That was the end for me, so good luck to you all.
When the reveal showed the coin slot was a sticker, I thought they'd have a couple of different currencies or amounts on different stickers, like the license plates on the large car sets.
Something that stood out for me from the review is the use of peg boards really ends up looking like circuit boards before they are put in place.
Nice review and interesting set, but I don't have the space. I wish they would sell the side builds separately, those are fun for display and fit on the average shelf.
It’s very cool. Very nice and cleverly designed.
But looking at arcade1up, they have a real working PAC-Man table top, this size (not the smaller tabletop), but almost the same size as this LEGO one with 4 games (PAC-man, super pac-man, dig-dug and rally x) for $179.99.
Rather go with that.
BUT, for the gaming fan, this is still cool to have in your collection.
I'm a big fan of this - exactly the kind of set I like. But £200+ is above my threshold. I'll see if it gets discounted like the Bowser set has been.
This is the issue with sets like this, the typewriter, and the table football: As cool as they are, when the actual function of the object is part of the appeal, it gets to be a little harder to justify a Lego version.
I never understood comparing the price with that of the real thing. Isn't the point of buying Lego for the novelty of building a thing out of a bunch of parts that we can then use for anything else we want? Hot Wheels are cheaper than Speed Champions, y'know!
Anyways, even though it's not one I'm after or have the budget for, this is a cool set! Love the function of rotating Pac-Man and the ghosts turning blue, so simple but effective!
So, this is somewhat playable?
@Lordmoral said:
"So, this is somewhat playable?"
Not at all.
Will never understand the ‘I can just buy the real thing’ argument.
Yeah, you can. You can buy a ship in a bottle, a globe, a typewriter, an arcade machine, a world map. The beauty is in the construction, the build process; seeing your efforts as you construct a model out of plastic bricks come together.
You don’t buy a puzzle and then think you should’ve just bought a picture instead. It’s problem solving and a sense of accomplishment.
It’s all about the build, baby.
The build is nice, the moving functions are great but it's not playable.
Now we can wait for all the prank videos of people being fooled and believe it's a real arcade machine.
@sjr60 said:
"Looks absolutely brilliant. It's overtaken the Land Rover on my £200+ wish list. Will probably wait for a higher threshold GWP though (maybe the rumoured 'Houses of the World 2' rerun in a few weeks).
Obviously not a set for everyone. Especially not the 'What's the point when you can get a real one cheaper' brigade. I guess they're not big fans of the 'Botanical Collection' either! But personally, I love the 'Wow, they've made THAT out of Lego' sets!"
I don't think they have issue with the botanical collection. The botanical collection is often cheaper than the real thing as well as not dying(big plus for the flowers).
@chrisaw said:
"Will never understand the ‘I can just buy the real thing’ argument."
Sadly that often equates to 'I don't personally like it, so Lego shouldn't have made it'
@sir_vasco said:
"I never understood comparing the price with that of the real thing. Isn't the point of buying Lego for the novelty of building a thing out of a bunch of parts that we can then use for anything else we want? Hot Wheels are cheaper than Speed Champions, y'know!
Anyways, even though it's not one I'm after or have the budget for, this is a cool set! Love the function of rotating Pac-Man and the ghosts turning blue, so simple but effective!"
On the one hand: yes, the build is part of the appeal beyond display value. If it purely was about display value the real deal would be a no-brainer in all cases.
On the other hand: you can buy a LOT of bricks for that kind of money if you go elsewhere. Large ones, not 100 technic pins or something.
The real appeal of these is building something for hours on end and then being able to look back and say 'I built an X'. Which then means all you can do with it is either spend 5 minutes fiddling with the functionality, use it as a literal ornament or unbuild it and either build it again, part it out, or sell it.
Basically, this is for people who really, REALLY like that X so much they want to build it with lego once or twice and don't mind spending a lot of money just for that relatively short experience.
Personally, I like to rebuild stuff and maybe even make alternate builds. Good luck doing that when a set consists of this many parts. You cán do it. But it's not designed for that. These sets are all about that one time they are built and after that they are meant to just be left on display.
At that point the question is: if it looks like an X, and you want to look at an X... is building the X out of lego really worth paying double what you get for a REAL X that not only looks like an X. But is also... you know... the actual thing. And in case of these 'functional' sets like the piano, typewriter and game consoles they actually work.
So it becomes: If you REALLY want that probably once, twice or maybe four times in your life experience of building the set version of an X (probably once for most people) with lego and maybe get to part it out if you really dare to. Then these are for you. I understand that those who already have plenty of the real thing might like a lego replica.
Oh, and there might also be the people who use it as conspicuous consumption to show to others what they like and/or what quirky things they own. Who knows.
TL;DR: the 'you can buy the real thing for cheaper' crowd aren't wrong. In some cases you can, in fact, buy the real thing for less than it costs to buy the lego version. In that case the value becomes less about having the X for display or even the functionality and more about the limited buildability and potential to part out the set. Which, to be honest, becomes less easy to rebuild the bigger and fiddlier it gets.
So the 'real thing' crowd has a valid point that this might take the main draws of these sets (display and 'function') and outdo them, only leaving the building experience. And the fact that it is a lego version of the thing.
This does actually change the context around the decision to fork out the high prices for these sets for the people that care more about display and function over build and 'lego-ness', so this information is relevant.
I never really understand why they have a minifigure and scene in these sets, particularly as they are hidden out of the way. They seem to exist only to bulk out the price of the set, surprised they don't come separately as a GWP or exist as their own mini sub theme.
The previous one was hidden inside the Atari, which was even stranger.
I understand your critcisim about my comment concerning buying the real thing.
When things like this started to appear (typewriter, NES etc.) I thought it was cool that you could make a near life-size replica of a real thing out of LEGO, but now I'm starting to wonder what the point of doing so is given they are never functional.
This is a cool model and it offers an interesting building expeience, but once you've built it and turned the lever a few times, all that's left to do is look at it and watch while it gathers dust, and perhaps surprise your visitors when they find out it's LEGO.
I guess the same can be said for many 18+ sets these days and of course many AFOLs are fine with that.
Flowers do not have any functionality so can be replicated perfectly with LEGO, so I do not feel the same about botanical sets.
@ShinyBidoof said:
"It's good to see a number of other people finding the criticism that you can buy the real thing cheaper baffling as well.
I could maybe understand it from people who don't like Lego but it is quite bizarre on a site that is supposed to be for fans of Lego."
That's likely just a result of all the licensing lately. Nobody will complain about the accuracy of a City set. Meanwhile, sets like Star Wars are heavily scrutinized on accuracy. Once Lego decided to make it a recreation of an actual Pac-Man machine people were bound to compare it to the actual Pac-Man machine.
It also doesn't help that the price points are so high and the set is so focussed on display alone (see my post above) that they immediately aim for the more hardcore fans of the subject matter. I doubt many people will be able to throw that money at something just because it looks mildly interesting. Thus, you're left with heavy scrutiny and comparisons galore.
As a lifelong, dark-age less fan I can tell you that even though people like Lego they don't all like it the same way. Some are MOCists, some minifig collectors. Some set collectors. Some just like the toylines. Some might even like combining hobby's or have Lego intersect with a main hobby. As more people enter the hobby you'll only see more perspectives and values that go beyond liking something just because it's lego. Often, people might like the IP first and foremost. And that's okay too.
In fact, I daresay sets like this aren't aimed at lego fans. They're aimed at non-fans specifically and use the object created with lego in question specifically because this group might love the object and maybe grow to like lego once they are reeled in by the set. That's the marketing strategy here. "Adults Welcome."
I see a really big opportunity with this new part to make a chain driven fairground dogem's set
@Paul_DLH said:
"I see a really big opportunity with this new part to make a chain driven fairground dogem's set"
Yes it has great potential, in GBCs for example, too.
I really like the look of the set, but there's only so many times I can justify splurging out that much money on a LEGO set each year.
And I'm afraid this one is not going to make that list for me. I'd rather save that budget for the new Ninjago City set.
Ayways, even though it's not one I'm after or have the budget for, this is a cool set! Love the function of rotating Pac-Man and the ghosts turning blue, so simple but effective!"
I think in this case if you’re interested in Pac-Man and have this level of disposable income, a replica of an arcade machine would be a better purchase. It allows you to actually play the game and not just mimic it while taking out about as much space. That’s not to mention that the real deal will just look better than a LEGO imitation (no offense to the designer, of course)!
This, the foos ball table, and the typewriter raise the question of “why not just get the real deal”? Not everything on someone’s shelf needs to be LEGO. The real deal being a better deal just makes what LEGO has to offer often seem worse.
I understand the reason, but the pile of printed maze tiles feels like a cheat.
The moving bits are cool, but what I liked the best were the mini builds. Too bad they're not GWP to get or buy off market.
Super nice build. Too expensive for me, but if i had the money i most certainly would have made a cool place for vintage lego gaming sets. I hope they will make a commodore set as well, but i doubt they will. But it’s lego, you can make it yourself if you really want too!
I don’t get the “a working one is cheaper” criticism because that is just a completely different thing.
My only criticism is that it is missing two ghosts
I'm strongly in the "consider the fact that you can get the real thing for a fraction of the price" crowd, and very much against the idea that even considering the thought is somehow utterly unconscionable. The build experience of LEGO is great. A moderately experienced builder can assemble this set in ~5 hours. That's a one-time, half-day experience, and then you're done. The number of people who will take the set apart & rebuild it repeatedly to extract more of said build experience for their money is miniscule. The number of people who will take advantage of the LEGO system here and turn this $270 USD arcade into a motorcycle or spaceship or Jedi holocron MOC is tiny.
Most happy buyers of this set will assemble it, play with it a few minutes, then put it on display. The end. Compare that to a same-sized, working countertop arcade unit which does not have the brief build, but instead gives you 5 to 15 minute gaming sessions with far more visceral and nostalgic endorphins triggered by accurate sights *and* sounds, for months, if not years to come. When not in use, said arcade will simply be on display, just like the LEGO set. The LEGO build has the gee-whiz factor of a visitor to your house asking, "Wait is that real? Oh it's LEGO, awesome!" The working arcade has the gee-whiz factor of a visitor to your house asking, "Wait is that real? Oh it IS! Awesome!"
For folks open to more sources of entertainment and joy than just a single brand, it's absolutely valid to at least posit the question of LEGO vs. real thing, *especially* when the former costs nearly 2x as much, is loaded up with stickers, and will yellow over time. Variety of thought shouldn't be discouraged.
LEGO should sell the minifig scale PacMan cabinet. i'd rather that. As well as all the brickbuilt ghosts instead of just two.
Amazing, design, but why would I want this?
While I have no particular inclination to buy the set (no reason other than it not really being my thing) I do have to respect it as a masterpiece of engineering and design as far as Lego goes. I dread to think how many hours of thought went into getting that chain drive system working just right
"I would rather spend my money on the real thing." Okay, fine, go ahead!
"Why would anyone spend money on this when they could buy a real, working one?" I think you don't understand the very concept of a hobby: that is, something that interests you.
Sets like this combine two hobbies, that's the appeal to some people.
I have 10306 and 71374, but I don't think I'll be getting this one. Not because it's expensive (although that is part of it), but because they take a whole shelf, leaving no room! That said, I do think it's impressive, and agree with @brickalili that it's a masterpiece of Lego engineering that some designer must have wracked his brains to get working as intended. I also have 21327, but I don't think the "You can buy a real one for the same or less" argument really applies there, as most folks these days have a lot more use for retro video games than a functioning typewriter, unless they just want to use it as a display piece. And if that's what you're going to be using it for anyway...
@sjr60 said: "Sadly that often equates to 'I don't personally like it, so Lego shouldn't have made it'"
You see that in a lot of fandoms where people feel that their individual tastes are shared by the entire fandom.
@Huw,
Is this a Chris McVeigh design? He did 10306 Atari 2600, and I wonder if the score of 10275 is an Easter egg reference to 10275 Elf Club House which was his first Creator Expert/Icons set.
You've just described every single Lego set out there if you're an adult. Do grown men actually swoosh cars and airplanes around? The interesting building experience + cool display model is pretty much 100% the point of Lego isn't it?
Clever work with the moving parts and the design. I might rebrick the Pac-Man and ghosts display, and add the missing ghosts when the instructions become available. That would be a cool display piece.
I don't believe this is particularly aimed at current gamers. In the early 80s I loved Pac-Man (although not quite as much as Space Invaders before it!). But I've not played any video game for at least 30 years.
Hence, for me this is a superb combination of nostalgia, a great display piece and a bit of novelty action thrown in for good measure... perfect.
I have no interest in playing Pac-Man now, so have no interest in a real machine.
I think this is obviously a niche set and as such will probably sell somewhere between the volume of the Atari and the NES. Nobody can brand it a success or failure without knowing what the predicted sales figures were and how many sales are needed to make the project worthwhile.
Long live niche sets. I certainly wouldn't want Lego to produce nothing but universally liked top sellers.
@theJANG said:
"Variety of thought shouldn't be discouraged."
This is the best sentence I've read on BrickSet for years.
In the "Lego vs. real thing" debate, I just want to add: Not everyone WANTS the real thing, even when given the choice at a similar price point.
I didn't grow up in the generation that played Pac-Man in the arcades. Pac-Man as a game probably holds my interest for maybe half an hour tops. However, I've always loved Pac-Man from an aesthetic and a branding standpoint, and I do still like retro games as a whole. I also love Lego, and building static representations of things out of Lego. Knowing these things, a real Pac-Man arcade machine in my home would do absolutely nothing for me. It literally serves a completely different purpose, and even if it costs less, it wouldn't give me the value that the Lego set does.
Would some see that as a weird way of thinking? Maybe. But as some have already said, variety of thought shouldn't be discouraged. Well then, also consider the perspectives of the types of people who *do* want this set, and realize that just as a Lego set does not provide the same value to everyone, neither does a real working arcade machine.
Whether the set is or isn't for you, does not mean it has no reason to exist.
I suppose the blue build in the minifig scene is meant to be a coin changer? You certainly needed a lot of coins back then...
This is an interesting one. I certainly appreciate the thought that's gone into the design, and the fact that PacMan and ghosts are movable at all is awesome. I don't have any nostalgia for it though, it's well before my time, and as such this was never going to be a priority.
I also have to agree with what @theJANG and @Binnekamp state above - unless you're a massive fan of this particular IP as well as Lego, it's not worth the money when the real deal can be purchased for less. I'd consider buying the 2 side builds, but given the large number of £200+ sets that there are at present, this ain't going on my list.
@MrClassic said:
"I suppose the blue build in the minifig scene is meant to be a coin changer? You certainly needed a lot of coins back then..."
It looks more like a trash bin to me.
I understand the comments about cameras, globes, typewriters, pianos, and video game consoles. But, I have to respectfully disagree with @theJANG .
Everyone is entitled to their opinion, and I enjoy hearing all of them. However, hearing Lego professionals like Jang and @Huw criticize a Lego set for essentially being an expensive dust collector on an AFOL site is simply an exercise in self-loathing.
All of our sets... and MOCs, fall into the same essential category unless you constantly play with them or deconstruct them and rebuild. The fact that we have large permanent to semi-permanent displays and have to share dusting tips belies the fact that we don't even play enough with our Lego to keep the dust off and make them shiny whith our finger grease.
I could easily see someone enjoying this as a dust-play item in a game room, Lego room, office, etc. This set is really no different than any other- especially the big sets.
I think most of the negative comments are merely a reflection that most of us are reaching the end of some Lego limit- space, time, money, or patience of our loved ones. That was inevitable, I suppose.
For myself, I won't be buying this until it reaches the BIG discount stage.
EDIT: BTW, I love the work you do, Jang and Huw, hope you keep it up!
@FuddRuckus said:
" @Huw,
Is this a Chris McVeigh design? He did 10306 Atari 2600, and I wonder if the score of 10275 is an Easter egg reference to 10275 Elf Club House which was his first Creator Expert/Icons set."
No, Sven Franic.
@bcontant said:
You've just described every single Lego set out there if you're an adult. Do grown men actually swoosh cars and airplanes around? The interesting building experience + cool display model is pretty much 100% the point of Lego isn't it?"
Fair point, but I think there is a difference between say, the John Deere skidder I revewied last week, and this. The skidder is a model that replicates the functions of a real machine in miniature from which you can learn how it works, whereas this is something that looks like a real machine but doesn't function like one.
Absolutely! I agree with the essence of your point (see, above).
However, the day I stop zooming, swooshing, wooshing (sailing ships), whrooming, and pew-pewing is the day I put it all on Bricklink and call it quits!
"All of our sets... and MOCs, fall into the same essential category unless you constantly play with them or deconstruct them and rebuild. The fact that we have large permanent to semi-permanent displays and have to share dusting tips belies the fact that we don't even play enough with our Lego to keep the dust off and make them shiny whith our finger grease.
I could easily see someone enjoying this as a dust-play item in a game room, Lego room, office, etc. This set is really no different than any other- especially the big sets. "
There are other options. I rotate the sets I display and regularly build and disassemble. Of course large sets like these don't scale well in such a system so I don't often go for anything large. But it's actually not that display based.
I mostly just use the little room I have for storing the built models in a way that doubles as display. Ever so often I take them out and fiddle with them, swoosh them or play around with them too.
One thing I feel will inspire the Lego group or a top MOC builder is with this new element and the way this all functions in this set, someone will come up with a new Lego game that properly uses this technique and function.
An all-new original Lego game you build and play with a point system, competitive, etc.
I think that will happen.
Maybe JK Brickworks will come up with something.
@Huw said:
"No, Sven Franic."
Thank you!
" However, the day I stop zooming, swooshing, wooshing (sailing ships), whrooming, and pew-pewing is the day I put it all on Bricklink and call it quits!"
The day you grow up is the day you grow old. Never surrender to the exterior grouchy old man (or woman), instead, be a kid inside forever - no matter your physical age! Remember: age is just a number!
For the record I think this set looks great, its concept & execution are fantastic from a LEGO perspective, and this very positive review does it justice. I smile every time I look at the pics and the extra effort of the short embedded video is a wonderful value add. I can't wait to be able to buy this thing in a few days & see how well this all translates to the real-world ownership experience. The price, and what else I (as a consumer, not a reviewer) could acquire for that amount (or far less) is the only thing that gives me pause.
By in Taiwan,
As an AFOL who isn't as hardcore, I appreciate the price comparisons to "the real thing" for all of the replica sets that Jang and Huw do.
For me, the point of paying a premium for Lego is primarily the fun building experience. So, the "I can get the real thing for cheaper" argument is invalid.
If you value the end result more, there are better options out there IMO.
@Huw said:
Fair point, but I think there is a difference between say, the John Deere skidder I revewied last week, and this. The skidder is a model that replicates the functions of a real machine in miniature from which you can learn how it works, whereas this is something that looks like a real machine but doesn't function like one."
So are you saying that all my Star Wars sets are pointless dust collectors? Let’s face it, my X-Wings can’t fly, and im yet to blow up a planet with my Death Star. Personally I think it’s amazing that they can create movement in this set in a similar but completely different way than they did with the NES set. I think the engineering that goes on behind this is absolutely incredible. Of course you can’t play the games, but replicating the look of them is incredible.
Now here is my issue with this set. When the NES set came out, it was a day-one pre-order for me. But that was easy, I already owned 2 NES consoles and nearly 50 games, plus the NES Classic, a NES Advantage, and even a U-Force (I’ve since added a ROB and several other items to my collection).
However Pac-Man is very problematic for me. Yes, I own the game for Game Boy and other consoles, but I’ve always wanted an original arcade cabinet. Problem is, aside from the price and potential maintenance issues, the size is a major problem. How would I transport a cabinet and where would I put it. Arcade 1-Up has come up with a solution for most of these problems, yet I haven’t bought one. I suppose it’s not real enough. But this Lego set too isn’t real and I love it. So if I’m going to spend this kind of money, it just seems like it would be better spent on the Arcade 1-Up, which thanks to this set I’m strongly considering.
Perhaps after I get an Arcade 1-Up I will then consider this set. It does look amazing, even if that is mostly due to stickers.
So I suppose the argument that you can get a functional one for a similar price is valid so long as you don’t already own a functional one and it is feasible to obtain one. However, if you already have a functional one, then that argument gets thrown out the window.
Yes, grown men do swoosh cars and aeroplanes around.
"However, the day I stop zooming, swooshing, wooshing (sailing ships), whrooming, and pew-pewing is the day I put it all on Bricklink and call it quits!"
Preach it, my brother in Lego! I swoosh stuff all the time, and occasionally get 42128 off the shelf to play with the functions.
@legoDad42: I wouldn't be surprised if good ol' JK (Brickworks, not Rowling) has already started planning something.
@Murdoch17: "We don't stop playing because we grow old, we grow old because we stop playing." Alternately: "Old age is all in your mind. The trick is keeping it out of the rest of you."
I first learned what a differential was and how it worked through building 8865 Technic Test Car :)
I have no strong opinion on this set vs the real thing; both have their place. I think this is a great set and a valid attempt with lots of merits. I am glad LEGO made it. It will inspire tweaks and the new technic link piece alone will allow great engineering MOCs.
There's no way it could have been avoided, but the rotatation of the character tiles on the chain mechanism just torpedoes the entire effect of the moving characters for me. I can't get past how sloppy it looks, to the point that I feel like this was an inherently flawed concept. I'll admit I was never going to be buying this set, but as someone even passably familiar with the game, I find the visual effect of this set's mechanism to be really hard to praise.
Just a quick friendly note.
Redo the video in the review.
Your cranking it the wrong way. PAC-man is going in reverse in the video.
Should be going forward. Mouth open forward.
@legoDad42 said:
"Just a quick friendly note.
Should be going forward. Mouth open forward. "
I wound it clockwise which I think you'll agree most people would. The issue might be that I threaded the chain the opposite way to the instructions.
I wound it clockwise which I think you'll agree most people would. The issue might be that I threaded the chain the opposite way to the instructions. "
I wonder if Tiago Catarino did the same... He also commented on having to wind anti-clockwise feeling a bit unnatural.
@alfred_the_buttler said:
"So are you saying that all my Star Wars sets are pointless dust collectors?"
No dust collector is pointless... Dismantling, washing, rinsing and reassembling is very therapeutic!
I dunno. Having a Pac-Man going backwards and upside down would make me insane to watch. And the dimensions of the Pac-Man and ghosts vs the maze are wildly off. So, cool function, but falls flat for me. I love the cabinet though!
@legomaniac said:
"LEGO should sell the minifig scale PacMan cabinet. i'd rather that. As well as all the brickbuilt ghosts instead of just two."
These are the poly bag and small box sets that would compliment the larger set and drive more sales.
The arrow on the back of the box seems to suggest that it should be turned anti clockwise indeed.
Well I did it. I broke down and bought an Arcade 1up Pac-Man. Thanks Lego for making me spend $250.
Having just assembled the Loop coaster and its 250-ish chain links a couple weeks ago, the repetitive pain to my fingers is still fresh in my mind. I took a break from building it after that step and resumed a few hours later.
@Huw did putting all those pegs in place hurt your fingers after a while?
Pac-Man is perhaps the most easily available commercial video game in existence. It was on the NES Classic. It's $4 on Steam. You can buy a tiny Pac-Man arcade machine while you're waiting to be seated at Cracker Barrel. One of the first few Google results for "pacman" is an HTML5 port you can play for free.
The point I was planning to make when I started typing was that the "but I could get the real thing so how could this appeal?" business feels particularly weird in this case because the "real thing" under consideration is already an expensive novelty and yet is actually *less* novel than a LEGO set that simulates a running game of Pac-Man by purely mechanical means. But also, I doubt it'll be long before somebody modifies it to turn it *into* the real thing.
Eh. I'll grab the "minifigures" if you will, from Bricklink. Maybe the arcade cabinet or at least the sticker sheet. Interesting, intriguing set but not worth it to me.
With all of these things, there’s a balancing act between nostalgia, authenticity and utility. With the Lego sets, the NES and Atari looked like the originals and the NES had that clever scrolling display. This Pac-Man set echos the NES with the interactive display but has less authenticity. It doesn’t particularly look like a Pac-Man cab. It’s more like a tribute, with elements of the design that are drawn from the original machine. And that makes sense – if it did replicate a cab, the set would be huge. And if it was instead more accurate, the display would be tiny.
But even with working machines, authenticity is variable. The Arcade 1Up units aren’t accurate in a visual sense and have multiple games included. The closest is probably the Quarter Arcade, but even there the screen itself is a modern flatscreen. (That company’s new TMNT units have a ‘Lena’ to mimic a CRT.)
So I get the criticisms. If you want a game to play, you need to get an electronic device. But if you’re a big fan of Lego and Pac-Man and would like a set that pays tribute to a classic game, I can see the appeal of the one Lego has created.
"You wouldn't download a car"
Me looking at the PDF instructions for Speed Champions sets:
It’s a real pinnacle of achievement in how to maximize the use of LEGO in ways that one wouldn’t necessarily think of when one sits down to create a model. It’s brilliance personified, frankly. Way above and beyond.
Should win an award or something, seriously.
I wish I wanted it.
@theJANG said:
"I'm strongly in the "consider the fact that you can get the real thing for a fraction of the price" crowd, and very much against the idea that even considering the thought is somehow utterly unconscionable. The build experience of LEGO is great. A moderately experienced builder can assemble this set in ~5 hours. That's a one-time, half-day experience, and then you're done. The number of people who will take the set apart & rebuild it repeatedly to extract more of said build experience for their money is miniscule. The number of people who will take advantage of the LEGO system here and turn this $270 USD arcade into a motorcycle or spaceship or Jedi holocron MOC is tiny.
For folks open to more sources of entertainment and joy than just a single brand, it's absolutely valid to at least posit the question of LEGO vs. real thing, *especially* when the former costs nearly 2x as much, is loaded up with stickers, and will yellow over time. Variety of thought shouldn't be discouraged."
Well said Jang, i strongly agree
"This set is emulating Pac-Man. Emulating is illegal! This is a crime! You wouldn't steal a policeman's helmet!"
That's an IT Crowd reference, right? Now that was a good show.
I so wished this one would actually be playable :(
